Transmission noise - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 1st Generation (1995.5–2004)
1st Generation (1995.5–2004) 1st generation Tacoma information and discussion.
Old 06-23-2008, 12:16 PM   #1 (permalink)
View chugalugz's Photo Gallery
Transmission noise
I have a 96 Tacoma (AT). Everytime I come to a complete stop, a sound comes from under the truck. It sounds like a "clunk". Trani?? You can also feel the "clunk" It shifts ok, no problems there. It happens when I am driving at higher speeds then come to a complete stop. Any ideas??
Thanks,
George.
chugalugz is offline   Reply With Quote
Old 06-23-2008, 03:44 PM   #2 (permalink)
prerunner specialist
trdcoma's Avatar
View trdcoma's Photo Gallery
do you have any lift oon the rear leafs? block or shackles...I think they call it axle wrap... someone told me its not bad? Im not 100% sure but my truck does it too. It started doing it after i put the 2" blocks on.
Looking for second gen trd supercharger, new or used. also, looking for new or used adjustable coilovers. Lemme know what you have!!!
trdcoma is offline   Reply With Quote
Old 06-23-2008, 04:57 PM   #3 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1265264
View humanoid's Photo Gallery
Axle wrap... worn rear springs will cause that. Also greasing your slip yoke, zerks and u-joint will cure the problem temporarily. Tacos are notorious for axle wrap.
This is my sig.
humanoid is offline   Reply With Quote
Old 06-23-2008, 05:44 PM   #4 (permalink)
Trani
It does have a shakle lift in the rear. The shakle is geasable. I will grease it up and grease the rest. What would be a more permanent fix. Spring pack??
Thanks,
Old 06-23-2008, 06:00 PM   #5 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Yeah, a permanent fix would be new leaf packs or you could get a traction bar.
This is my sig.
Old 06-23-2008, 06:07 PM   #6 (permalink)
axle wrap
Price, leaf pack vs. track bar?? What is a good place to start looking for either.
Old 06-23-2008, 06:40 PM   #7 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Leaf packs:
http://downeyoff-road.com/Suspension...04_Tacoma.html
http://www.wheelersoffroad.com/9504tacoma.htm
traction bars:
http://www.rockymountainsusp.com/tractionbars.htm
http://www.budbuilt.com/new/traction_bars.html
These are just a few to start with, good luck.
This is my sig.
Old 06-23-2008, 10:21 PM   #8 (permalink)
Thanks, humanoid.
George.
