CEL on 00 Tacoma - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 1st Generation (1995.5–2004)
1st Generation (1995.5–2004) 1st generation Tacoma information and discussion.
Old 02-05-2004, 09:07 PM   #1 (permalink)
View y00j912's Photo Gallery
CEL on 00 Tacoma
Hi, I just registered since I bought a Toyota . Look forward to meeting some people. I'm trying to learn more about cars and forums are a great place. Hopefully, you guys/gals will help a noob out. Anyways, here's my problem already:
I just bought a 2000 Toyota Tacoma and 2 days later I got a CEL.
I went to AutoZone and it read the following:
P0136 - O2 Sensor malfunction, bank 1 sensor 2
How should I go about checking this? I didnt want to just change the o2 sensor since that may not necessarily be the problem. Also, how do I find out what part I need if it is the o2 sensor? The stealership wants to charge me 85 dollars just to diagnose what I already know from the OBDII scanner.
Appreciate any help......
-B
y00j912 is offline   Reply With Quote
Old 02-10-2004, 10:30 PM   #2 (permalink)
View tbn15-oilman's Photo Gallery
How many miles?
have you or does it appear the front and or the Cat have been replaced?
I would say that it is possible.
I do know the front one on the 97 seems to
go after about 80K
tbn15-oilman is offline   Reply With Quote
Old 02-11-2004, 01:17 AM   #3 (permalink)
Sleeping While Awake
View 94 Yota's Photo Gallery
http://yotatech.com/showthread.php?s...nsor..........
www.oxygensensors.com
There's also http://www.partznet.com/ which will sell you a real Toyota sensor for about $93 the last time I checked.
94- 22RE, 5spd, 33x12.50, Engbldr 261 cam
To Come:
5.29's, rear E-Locker, front tru-trac, 35's, Bobbed Bed,
blah blah blah
94 Yota is offline   Reply With Quote
Old 02-11-2004, 11:41 PM   #4 (permalink)
Originally posted by tbn15-oilman
How many miles?
go after about 80K
I have 78,000 miles on the truck. I've reset the ECU and it came back with the same code. Bank 1 sensor 2 is pretty dang expensive.
The cat doesn't look like its been changed. I'm gonna test the o2 sensor with my multimeter this weekend to see if that's really the problem. Do you know if I can pass emissions with that o2 sensor malfunction?
-B
Old 02-11-2004, 11:44 PM   #5 (permalink)
Cool...thanks for the links. Time to do some reading
-B
Old 02-12-2004, 08:02 PM   #6 (permalink)
In my experience... 80K is about right for the front at least. If you still have problems, then replace the rear.
Yes, it is a lot of money...
You can try this:
With the truck cool in the morning, look under there and find the o2's, clean them with a damp towel with water only, often times I am told that just dirt clogging the air passage can trip a code. if it looks dirty that may solve the problem. It, if coated with oil, is likely dead. Oil will kill them.
Whatever you do, if they do go out, get the codes reset with the ob2 reader or you may have more problems.
In my experience, usually within about
5-10 miles after installing a new one, the light will go out on its own... sometimes it will take about 70 miles and sometimes 200 miles, but you don't wan't to wait... get it reset asap.
And no, if the cel is lit, it won't pass.
I have a problem that mine keeps throwing a p0420 cat below threshold...
Tacomas seem to have a lot of problems here from the people I know. Mine is like a nightmare, I hope yours is not.
Old 02-15-2004, 11:28 PM   #7 (permalink)
Offical nut
redfox435cat's Avatar
View redfox435cat's Photo Gallery
Since 96 if the vehicle will not pass smog the cel will come on. It's a good probably it won’t pass smog. Note: passably won’t pass.
4x4 v6 04 tacoma
Your Driving?Were we going?
redfox435cat is offline   Reply With Quote
