the Tacoma engine is entirely different than the 22R or RE, the 2.4 taco motor is a Dual Over Head Camshaft 16 valve engine, the 22RE is a single cam 8 valve, the intake and exhaust are on opposite sides also, and the 2.7 which is used in the 4x4's is basically the 16 valve 2.4 stroked to increase displacement up to 2.7, the 2.7 block is different because it uses balance shafts, but i think that the heads between the 2.4 and 2.7 are interchangeable, the engine code for the 2.4 is 2RZ-FE, and 2.7 3RZ-FE, i think that Toyota got the extra horsepower and torque from the new head design and higher compression ratio
