A/C screeching 2002 Tacoma
All, read through a lot of threads on A/C and need a little advice. Sounds like it could be the clutch or compressor from the threads. Replaced my timing belt on my 2002 tacoma prerunner two weekends ago and had to drop my A/C compressor to replace the timing belt tensioner. Replaced all belts and hadn't used the ac until last weekend. Turned it on and very load screech started. Haven't turned the ac on since. A/C worked fine before the belt replacement. Have probably a max 1/2 inch of play in the A/C belt. Belt seems tight as the other two. Any ideas on what the problem could be.
Thanks
