1998 Tacoma passenger floor wet - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 1st Generation (1995.5–2004)
1st Generation (1995.5–2004) 1st generation Tacoma information and discussion.
Old 07-30-2004, 09:10 PM   #1 (permalink)
View cwkid02's Photo Gallery
My passenger floor is wet under the floor mat. I have checked the condensation tube and it appears to be secure w/o any cracks or splits. I cannot find any trace of leakage from the condensation tank. Thanks for any suggestions in advance.
KG
cwkid02 is offline   Reply With Quote
Old 07-31-2004, 03:21 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
is this just with rain or when the a/c is on? well i'm guess with the a/c. i have the same problem with my 87 4runner. the problem for us is where the condensor tank meets with the rest of the vent system there is a foam gasket that runs around the matting point, check to see if that is leaking.
^ and leaving it that way!
Old 08-02-2004, 01:59 PM   #3 (permalink)
\m/ ^_^ \m/
View XB~Blondie's Photo Gallery
My 89 P/U would get wet on that side when it rained/after a wash, because of the antenna wire leaking into the truck (not sure if that prob. would apply to the newer trucks, but that's my info for ya )
XB~Blondie is offline   Reply With Quote
Old 08-03-2004, 12:37 AM   #4 (permalink)
robinhood150's Avatar
View robinhood150's Photo Gallery
I'd say your condensation tube is plugged, not cracked. Check it from the outside. When I pulled my tube from the firewall, a deluge of water came pouring out.
'93 4Runner V6 Auto 4x4
Robinhood's Lair.
robinhood150 is offline   Reply With Quote
Old 08-05-2004, 07:55 AM   #5 (permalink)
Still in process
Hey, thanks for the ideas. I'm still in the process of tracking it down. My wife drives the truck most of the time as I have to drive a service vehicle. I have pulled the drain tube from the tank after running a cleaning wire up it. It does no appear to be plugged since it does drain well on the outside. It is possible by looking at the inside of the tube that goes through the firewall that it may have not formed a tight seal and leaked there. I have taped a piece of newspaper to the underside of the tank and to the drain tube and let a/c run for 1/2 hr. and no leaks so far. I hope this takes care of it. Time will tell. Thanks to all for the feedback. Keep on Trucking!
KG
