2002 Tacoma Timing Belt replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 1st Generation (1995.5–2004) 1st generation Tacoma information and discussion.
post #1 of 13 Old 10-26-2005, 02:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I'm in the procees of needing to change my timing belt on my 2002 TACOMA. I looked for a manual for the truck at the autoparts store (AutoZone, etc) and they said that the truck was to new and that book was not out yet.....so went to the dealership and there was 4 different sections on the truck for $100 a book. Is there anyone out there that can help me with this.....Its not that I don't know how to do the job its just that I need the manual because when I did this before on another toyota I had the manual and it made it real easy......just wanted to see if anyone has a website where I can find the manual......or any info on how to do this project.....Thanks
fajkus1 is offline
post #2 of 13 Old 10-26-2005, 10:15 PM
Quoted: 0 Post(s)
This is the procedure for 2001-2004 Tacoma with the 3.4 V6. I am assuming the 3.4 as you stated timing BELT.
Remove
http://65.200.1.6/FSM/Repair_Manual/...imbel/remo.pdf
Install
http://65.200.1.6/FSM/Repair_Manual/...imbel/inst.pdf
The entire factory service manual can be found at http://fsm.afraid.org/.
Have a blast!
waldog is offline
post #3 of 13 Old 10-27-2005, 02:32 PM
lancekilgore's Avatar
Quoted: 2 Post(s)
For some reason I can't get the Http://fsm.afraid.org to pop up any body else haveing thath problem?
Fajkus1 why are you changing the belt did you hit 90,000 already?
lancekilgore is offline
post #4 of 13 Old 10-28-2005, 06:34 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yep bout a month ago I did.............and I'm not having any problems
Thaks WALDOG for your help.....!!!!!
fajkus1 is offline
post #5 of 13 Old 09-25-2009, 05:47 AM
rocketeer928's Avatar
Quoted: 0 Post(s)
Remove
Install
These two pdf links don't work. Can I find this information elsewhere? Thanks.
rocketeer928 is offline
post #6 of 13 Old 09-25-2009, 09:22 AM
Quoted: 0 Post(s)
The 2001 - 2004 FSM documentation is currently available at:
http://www.*******.com/fsm/2003/index.html
EnolaGaia is offline
post #7 of 13 Old 09-26-2009, 01:57 AM
Quoted: 0 Post(s)
4 cylinder
my 2002 has 100k on it. does anyone have a like for changing the chain on the 4 cylinder?
i have done this on my 91 yota already. not that hard to do for me. just took up a saturday.
vernon is offline
post #8 of 13 Old 09-26-2009, 09:07 PM
Quoted: 0 Post(s)
Haynes has a manual for the 95-04 Tacoma. I think I bought mine at Auto Zone or Pep Boys.
2004 DC 4x4 TRD, DR COILOVERS, DEAVER 8 PACKS, BILSTEIN SHOCKS, LINE X. 265-75-16 BFG A/T'S ON STOCK WHEELS.
Jakesdog2004 is offline
post #9 of 13 Old 09-26-2009, 10:25 PM
Quoted: 0 Post(s)
1991 link
the link that some one gave me on this sight about the timing chain on my 91 yota was far better than any haynes manual that i have on any of my trucks. it was easier to follow and gave better details to what i was trying to do.
an example on my 91 yota thier is a hidden bolt that is in the head that is in a place that fills up with oil. you have to remove this bolt to remove the timing chain cover. haynes manuel does not even talk about this. i know people that have cracked thier heads because of this.
this is just one example.
but honestly you can get better links to download from people on this sight than what you can buy.
i am hopeing someone will read this and share one with me for my 2002 4 cylinder.
the job on my 91 i saved about $350 doing this myself.
vernon is offline
post #10 of 13 Old 09-29-2009, 05:55 PM
Quoted: 2 Post(s)
I don't think you are even close to needing a chain change. Usually they need replacing when the stretch enough to throw off the timing. between 150 to 250k
hossmaster is offline
post #11 of 13 Old 09-29-2009, 09:43 PM
Quoted: 0 Post(s)
i think that you may be right
on my 91 yota i paid someone to do this for me around 175000 miles then i did it myself at 300000.
i might wait another 25000 miles of my 2002. but i would still like to get my hands on a link that i could download to save for when i discice to so this.
vernon is offline
post #12 of 13 Old 12-29-2010, 10:48 PM
Quoted: 0 Post(s)
Timing Belt/Waterpump lessons learned
Just did my timing belt, waterpump, etc and wanted to pass along my lessons learned. I read up quite a bit, but don’t remember seeing these thoughts:
Protect the radiator with cardboard or remove it. I darn near damaged a fin
If you plan to replace the cam shaft oil seals, remove cam shaft bolts before the old timing belt so that you can use the leverage of the crankshaft bolt to hold the pulleys. Alternatively you can use a strap wrench.
If you don’t have a 250LB impact gun, use a heavy duty strap wrench, sand paper, and double sided tape to remove/install the crankshaft bolt
Use a dremel with brass wire brush to do the final clean on the waterpump mating surface. It corrodes and pits due to dissimilar metals between the aluminum housing and the metal/rubber gasket. More then scrapping is needed.
2.5 gallons of anti-freeze are needed
The special snap-on pulley spreader tool works well, but I needed to leave it in to get the belt on. The pin didn’t hold the tensioner back enough. Also, make sure the pin hole is in alignment first.
Pressure wash the engine before working on it. I had planned this, but it was raining/cold the past week.
Cryoman
Cryoman is offline
post #13 of 13 Old 12-30-2010, 07:43 AM
Quoted: 2 Post(s)
Good points, I just did mine last month and every thing you said is correct. I removed the tenioner since I did not have the special tool and used a vice to press it in. I actually found it easier with the tentioner removed. very fun job but I am glad it was done surely don't want the belt to break on me.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 1st Generation (1995.5–2004)
User Tag List
Linear Mode Linear Mode
« Back
