The leak turned out to be on the cab between the bed and the cab wall. A bad weld and bad sealant causing storm water and road water to enter cab area.
Mike
I have an o2 Toyota pu with extended cab, 4cyl. it keeps leaking behind the drivers seat on the floor board, I don't see where any water is getting in but its soaked, do you know what I could check or what the problem could be?
Welcome to TN. I moved your post into a new thread in the 1st Gen forum.
As for your water leak, the quickest method to finding the source of the leak is to remove the carpet and trim and look for the source starting with a hose.
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
588.4K members
Since 2001
