Replace bench seat on 97 Tacoma - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 1st Generation (1995.5–2004) 1st generation Tacoma information and discussion.
post #1 of 5 Old 11-19-2007, 01:07 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 1997 regular cab 4x2 Tacoma. How difficult would it be to replace the standard bench seat with two bucket seats from an extended cab? Would the console mount right in or would it require drilling?
And finally...where can I get these parts? I can't find the console anywhere!
matts8008 is offline
post #2 of 5 Old 11-19-2007, 07:26 PM
Quoted: 0 Post(s)
Yes - you can bolt bucket seats from a same-era Tacoma into your bench-furnished truck. The bench seat assembly doesn't use all 8 of the bolt holes used for the pair of buckets. The extra holes (depending on year) are either (a) pre-molded in the floor pan (just drill 'em out) or (b) pre-drilled and plugged (just remove the plugs).
If I recall correctly, the bench seat's seat belt anchor / receptacles don't transplant onto the buckets, so make a point to get the inboard bucket seat belt anchors along with the seats.
EnolaGaia is offline
post #3 of 5 Old 11-20-2007, 06:52 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
How about the center console? Where can I buy that and will it bolt in?
post #4 of 5 Old 11-20-2007, 02:17 PM
WheelinIdaho
monkeee2002's Avatar
Quoted: 0 Post(s)
Here's one.
EDIT: Mine looks a little different, though.
I don't have that odd formation of indented areas in the front-ish pocket.
1997 Reg. cab 3.4L 5 sp. 4x4 Deck plate, TB spacer, all custom lights, white gauges, Billet grill, Herculiner, hidden hitch, OME 881 front coils & Wheelers 5-leaf rear springs w/ AAL, BFG AT-KO 31x10.5, and QuietKote. SOLD, but missed.
monkeee2002 is offline
post #5 of 5 Old 11-23-2007, 12:13 AM
forget about "tsb's"
6shooter's Avatar
Quoted: 1 Post(s)
i swapped my 60/40 for a pair of buckets and just left the center part without a console.
6shooter is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 1st Generation (1995.5–2004)
User Tag List
Linear Mode Linear Mode
« Back
