1995 Tacoma 3.4 V6 high RPM - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 1st Generation (1995.52004) 1st generation Tacoma information and discussion.
post #1 of 8 Old 01-16-2008, 01:46 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 1995 Tacoma SR5 3.4 V6 4x4 automatic. It seems to idle extremely high. I've mentioned this to a couple mechanics who have said they wouldn't worry about it. These were not Toyota certified mechanics. The engine idles so high that when I pull up to a stop I have to stay on the brakes to keep the truck still. This is really bad when the engine is cold but it is noticable even after the engine has heated up to normal range.
Can anyone give me a round about listing of idle RPM numbers for their 3.4 auto's? If my numbers are much higher than average, I plan on taking mine to a Toyota mechanic.
ericwilson54 is offline
post #2 of 8 Old 01-16-2008, 03:04 PM
Quoted: 0 Post(s)
It should'nt be idling any higher than 800rpm's when you are at normal operating temp you may want to start looking at your idle air control valve that would be the first thing to look at
stshannon is offline
post #3 of 8 Old 01-17-2008, 08:59 AM
12guns's Avatar
Quoted: 0 Post(s)
May be a dumb answer, but I did this once...
Make sure the accelerator cable is still in the guide propperly. On time I was jumping another car and pushed the accelerator by hand, when you do that the cable can jump out of the guide. Just a quick fix to look for. Good luck w/ the problem
12guns is offline
post #4 of 8 Old 01-17-2008, 10:16 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Good info
Thanks for the responses guys. I'll pay close attention to my gauge on the way home to today. I'm pretty sure my idle RPM is close to 1000 at normal temps.
post #5 of 8 Old 01-17-2008, 12:07 PM
Quoted: 0 Post(s)
Make sure your air filter is clean, when my air filter was trashed my truck was idling around 1200-1500 at stop lights.. then i threw a new one in and back down to 700
My baby, 2000 Tacoma PreRunner V6, Custom Sound System , Rims, Tires, SnugTop..so far
s4ndwich is offline
post #6 of 8 Old 01-17-2008, 07:17 PM
Taco lover
Quoted: 0 Post(s)
I've installed the deck plate mod since last winter, so this is the first winter with it in place. Earlier this winter I noticed that the engine seemed to idle high for a very long time with the deck plate cover off.
I've put the cover on, and I think the idle comes down quicker.
May be my imagination, though. That'll happen!
Cheers,
Ric
1998 Tacoma TRD - Bought back by Toyota in 2/13 for frame rust.
Currently driving a 2000 4Runner and loving it!
riceye is offline
post #7 of 8 Old 01-18-2008, 07:12 PM
Quoted: 0 Post(s)
Talking 95 high idle
youre idle should be around 700-800. my 95 had a bad coolant temp sensor cheap ins for 30 bucks. clean iac valve make sure no junk inside but dont touch any screws on it or throttle body. also check air filter clean ?. must remove throttle body to get to iac valve. if found bad i have new toyota valve i obtained through friend. prob temp sensor. its behind top rad hose. youll need 3/4 12 point socket and remove bolts for timing belt cover. anyquestions fingers8@verizon.net
fingers8 is offline
post #8 of 8 Old 01-18-2008, 09:22 PM
Offical TN Hillbilly
TcmaBoy's Avatar
Quoted: 0 Post(s)
Everybody likes to point at the IAC, but you should also look for vac leaks, and make sure the throttle opener is properly adjusted and working.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 1st Generation (1995.52004)
User Tag List
Linear Mode Linear Mode
Back
