Bypass oil filter installation - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 1st Generation (1995.52004) 1st generation Tacoma information and discussion.
post #1 of 4 Old 03-12-2008, 03:59 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Been lurkin awhile....this is a very informative forum...
I'm interested in installing a bypass oil filter in my 00 pre runner w/ V-6 (5VZFE)...need a feed line and a return line...what are good locations to attach them....don't really want to drill holes in engine/pan....thanks everyone!
Flyin_V is offline
post #2 of 4 Old 03-13-2008, 12:01 PM
Quoted: 0 Post(s)
If you use a sandwich plate as an OEM oil filter location adapter, some of them have the inlet / outlet ports built right into them.
If you're doing custom lines ... I've seen installations where the return line is sent back up to the valve cover (probably too high for good flow, but I've seen it). I've read at least one writeup in which the guy somehow plumbed his return line into the OEM oil cooler unit on the 5VZ.
EnolaGaia is offline
post #3 of 4 Old 03-14-2008, 04:07 AM
WheelinIdaho
monkeee2002's Avatar
Quoted: 0 Post(s)
Uhh, are you trying to build something like this from scratch?
1997 Reg. cab 3.4L 5 sp. 4x4 Deck plate, TB spacer, all custom lights, white gauges, Billet grill, Herculiner, hidden hitch, OME 881 front coils & Wheelers 5-leaf rear springs w/ AAL, BFG AT-KO 31x10.5, and QuietKote. SOLD, but missed.
monkeee2002 is offline
post #4 of 4 Old 03-16-2008, 02:31 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thumbs up
that looks like it might work...I could put 't' fittings on the feed and return lines for the bypass filter...I'll try and find out if there is enough pressure and flow to support both filters...
Thanks!
Flyin_V is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 1st Generation (1995.52004)
User Tag List
Linear Mode Linear Mode
Back
