Well, For the longest time, my dad's '96 Cam Wagon has not felt right. I got it aligned and wheels balanced and it got worse. I now rotated the tires not too liong after and the car shakes bad. The alignment is WACKED. Pulls hard to the left while steering wheel is cocked like 10 degrees tot he right. He hit a log years back witht he rim and says the rim is perfectly fine. I need your input fromt he following pictures. Is the rim the cause of the shaking and alignment quickly going bad. He says it is not bent much at all.
so long as the picture isnt really decieving i have to say that rim is bent. At higher speeds i can imagine how much vibration u must be feeling and how bad the car must be feeling. If ur dad hit a log theres probably stuff wrong with the steering linkage and stuff too...
Get a another rim, the steel ones like you have are cheap---real cheap in a junk yard and then get the vehicle re-aligned. That rim looks like garbage.
P.S. Nice sig---I used to drive through Hartford, it is the ghetto, but I'm from Springfield so its not much better.
could be bad axles. that's typically what causes shaking in Gen 3's. If you hear a pop when the wheel is turned (especially when its cold), CV boot could be torn, but the CV joint is bad so it needs to be replaced.
why does this apply to your situation? Bad CV (or Constant Velocity) Joints cause the car to shake when driven at speeds higher than 40mph or when shifting gears.
I know that is not it. That happened on my current Camry and it sucked. I know the mechanic has checked out these and they are fine.
Although, I am thinking that may be the problem with with my car ont he OTHER side now. Long story behind that saga though.
I actually just got back from driving too. I put my 15's on with NEW (new as of today, 0 miles) tires on frshly balanced rims. Vibration is now nearly nonexistant
actually, in terms of it being bent, that's hardly anything, and if it was properly and carefully balanced, it wouldn't create much, if any vibration at all, unless it's even worse than it looks there
quite possibly, it was due to a mixture of all your old tires and unbalanced rims put together
and more so the fact that one bent rim does not cause the kind of behaviour that you described
HaHa
"Life is a deep sleep, of which love is the dream..." Ripped...and the girls are loving it.
