part no.?
the problem is usually intermittent, that is also a 2 trip detection trouble code.( meaning the car has to see a certain set of bad values on 2 seperate key cycles) The part is about 80-95 dollars at toyota, its an ez repair,but hard to get to. its even tougher on the rav 4x4
I am a toyota master tech. so I am giving u sound advice. The vsv is the most common problem. if the egr itself was sticking, the car would stumble or die on decel.
The problem is , when u remove the part and test it, it sometimes tests ok. so its kinda of a educated guess by process of elimination.
If the part was bad all the time. u could clear the codes by disconnecting the battery. then drive it for a day and it should come on fairly quickly.. you drive the car up to 50 mph or so. stop, turn the car off, restart it and do it again. if the part was shorted, the chk eng light should come back right away..
good luck and keep us posted.
Hi DeeKay,
I have the RAV4, 1996, 4WD version and havieng the same problem with check engine light. Summary:
- Bought the car in November (used of course)
- Afer maybe 3-4 weeks, check engine light went on
- Car didn't stumble or so, and fuel economy was ok
- Took it to the Toyta dealer, scanned and found that oxigen sensor was the potential problem
- Guys there deleted and asked me to test and come back in a couple of days
- Same day I went out, check engine light (CEL) came on again
- This time I was having BIG fuel econmy problems (100 miles for full tank!)
- Also the car was stumbling badly and smell like a lot of gasoline
- Took to the dealer again, this time was not the oxigen but the MOP? sensor
- They were sure it was that. They ordered and replaced the MOP
- After this fuel consumption went ok, car didn't stumble at all
- Before arriving home, again the CEL went on!
- This time fuel consumption was ok, no stumbles either
- Found an AutoZone & got it scanned. Error showed EGR valve and selenoid flow problem
- Days after took it to the dealer, had the EGR cleaned (free of charge), deleted the error codes again
- Again, everything was nice, but just before my home (50 miles from the dealer) CEL went on again.
- This time everytime I turn on the car it revs at 2,000 rpm. After gets warm will drop to 1,100 rpm's (not the lovely and stable 900 rpm's)
- Also this time the car stumbles sometimes strong specially at very low speeds
- Have been reading recently on what to do.
- I decided to go for the VSV valve.
- Called the dealer and they said that most probably by cleaning the valve problem can get fixed.
- As the dealer is far away, I need to order in advance the part (VSV) so I can use my time better (just don't have the time to go back and forth so many times)
- Read there are two VSV... at the dealer they said they know there is a VSV and PVSV?
- Do you have by any chance the part no. so they won't get mixed up on which part to order and replace?
- Do you have any other suggestions on what the problem can be? (before I was about to replace the EGR but stopped after reading on the VSV).
Please help, this is so so so so frustrating...
