I'm wondering if anyone has experienced [from time-to-time] a brief, loud rattle noise for approximately 1 second at cold start-up. This brief (approximately 1 second) loud rattle noise (sounds like jerking a chain quickly out of a plastic milk jug) has happened with my 2004 V6 3.0L engine from time-to-time for about a year now. The noise is definitely not associated with typical cold start valve ticking, etc. that many people have. It is definitely coming from the intake-side of the VVT system.
Toyota has identified certain Lexus models built between 2006-2011 with this VVT noise problem, and issued a voluntary recall. However, Toyota apparently never had many customer complaints or problems to address any Toyota model vehicles with this same type VVT noise problem that I'm aware of. Plus, my car is now 11 years old with 128k miles...so it did not developed the problem until well after the original warranty.
The reason why I am offering this information is to help people (that may have this brief, loud rattle noise for approximately 1 second at cold start-up that may only happen randomly) that cannot figure out why or where the noise is coming from...
The following information describes the problem:
Bolts used to secure the variable valve timing control device can become loose, causing the vehicle to stop while being driven. Early warning for this condition can be identified as a brief rattle noise for approximately 1 second upon a cold start-up.
Description of Problem:
The subject vehicles are equipped with a Variable-Valve Timing (VVT) system which controls the camshafts to provide optimal valve timing under certain driving conditions. The bolts used to secure the housing and sprocket of the intake-side VVT gear assembly could become loose due to abnormal impacts generated within the gear assembly immediately after a cold start-up.
If this occurs, the VVT gear will not control the intake valves correctly. In certain cases, the VVT gear housing and sprocket could separate and result in the engine stopping while the vehicle is being driven, increasing the risk of a crash.
Toyota theorized that the condition could be related to an engine noise issue at start-up being investigated on certain engines. The VVT internal component could rattle when the lock-pin, which latches to the VVT housing and secures the internal components to maintain the camshaft in the most delayed position, unlatches at cold-start. Toyota conducted reproduction testing and was able to duplicate noise but was unable to duplicate the loose bolts condition.
Through reproduction testing, Toyota confirmed that, with the lock-pin disengaged during a cold engine start, the impact force between the VVT internal component and the housing could become larger if engine oil, which is pumped into the VVT unit to control the position of the camshaft, drains back into the oil pan while parked. In addition, Toyota theorized that the impact force varies in specific engine types due to cam profile and intake valve spring load. Toyota continued its investigation and testing to clarify the relationship between the impact force exerted inside the VVT housing at cold-start and bolt loosening.
I hope this information may be helpful...
