Hi all-
Been having some problems with my 94 22re.
Recently (2 weeks ago) I did a tune up... Plugs, wires, cap, and rotor and ever since then I have had an intermittent miss. One day it will run fine, others is will run absolute crap. It also doesn't miss under load... Just at idle. I ran the codes, and I came up with a MAF, and intake air temp. Are these able to cause a miss?
I pulled the plugs today, and the #2 plug was wet, while the others were normal... Inclining to me that my problem is in the #2 cylinder.
Haven't been able to run a compression test yet, but that is next on my to do list, when I can get my hands on a tester.
No oil in the coolant.
I have also been loosing coolant somewhere, but this has gone on since I have owned the truck... 3 years now. I don't think this is related, but who knows.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
