Wheels that will fit! - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 4 Old 02-06-2006, 09:20 AM Thread Starter
Dseldown's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Question Wheels that will fit!
Im looking for rock solid info on what other wheels from other car manufactures as well as any yotas that will fit my rotors/drums for my 91 yota PU 2wd, the specs are: bolt pattern- 114.3mm or 4.5" [same same] 114.3mm x 5 lugs holes. I have already tried wheels from a Ford Ranger and even though the bolt pattern is the same, the problem with them as well as others Ive looked at was the middle hole wasnt big enough to allow the wheels to be flush with the face of the rotors/drums. I measured the the OD of the rotors/drums W/calipers and it comes out to 2 5/8" or 67mm. I will not use wheel adapters as this will create an offset problem as well as not relying on them, I was advised not to die grind the hole to enlarge it as there were to many issues to list, mainly saftey! So what will fit in a 14" or 15" wheel? I cant go any wider than 7" and prefer a 15" x 6" wheel due to more numerous tire choices than a 14" but Ill look at any and all, just need a list of what model cars to scope out @ the bone yards that will fit flush to the faces W/ the correct bolt patern size. My stock steel wheels are 14x6" and want to upgrade to alloys, and am not ready to shell out big $ for aftermarket wheels unless as a last asolute resort. Thanks for any help guys.
Dseldown is offline
post #2 of 4 Old 02-06-2006, 07:04 PM
take chances, drive fast
Quoted: 0 Post(s)
i know that mitsubishi conquest or starion rims will fit the only thing you cant use is the center cap . but these rims are wide about 10" for the back i think is the stock width.camry rims wont fit because of the middle hole.
92toypup is offline
post #3 of 4 Old 02-06-2006, 08:26 PM
Offical Truck Nut
1bad2WD's Avatar
Quoted: 0 Post(s)
wheels
I got 16" cobra R wheels on my toyota off a mustang , they fit perfect . you can use rims off a mazda rx-7 5 lug cars and some of the oldsmobiles rims will work.
2002 Tundra V-8, cab TRD, limited 130,000
2002 Tacoma Regular cab 52,000
1bad2WD is offline
post #4 of 4 Old 02-07-2006, 04:51 PM
Quoted: 0 Post(s)
i know that plymouth neon rims do not fit
92toypup is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
