Help!!! No gauge lights... They worked yesterday! - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 7 Old 05-30-2006, 09:04 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Just purchased a 94 pickup.. All the gauge lights worked yesterday.. Instrument cluster, heater switch lights etc.. Now I go in my truck at night and the lights for the instrument cluster wont work and the heater lights wont work at all.. All the gauges work fine just no illumination.. I checked all the fuses and they are good.. My headlight and tail lights work.. The clock dims when I turn the headlights on... Can anyone help me?? Please!!!!!!
newbie212 is offline
post #2 of 7 Old 05-30-2006, 09:24 PM
nofear4189's Avatar
Quoted: 0 Post(s)
did you try and adjust the dimmer knob? its located to the left of the steering wheel. itll be a little round knob with a light bulb on it. Chances are that when getting out, your leg hit it and turned it, dimming the dash lights.
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
nofear4189 is offline
post #3 of 7 Old 05-30-2006, 09:45 PM
94SRUNNER's Avatar
Quoted: 0 Post(s)
Sometimes the lights in the instrument cluster can be knocked loose or they will sometimes vibrate loose. Check the dimmer knob first, just to be sure. Also check the fuse. If that does not work pull the dash panal and pull out the cluster and check the lights.
97' FZJ80 40th Anniversary Edition No. 4647 - 200K - No Lockers -CDL Switch/7-pin mod - Landtank MAF - ScanGauge II - Bilstein F/R & OME SS - 265/70R17 Michelin LTX AT2 on 17" FJ Cruiser Steel
94' Toyota Pickup 2WD - 253K - Street Machine and Daily Driver
94SRUNNER is offline
post #4 of 7 Old 05-31-2006, 02:07 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yes I am not stupid enough to not have the dimmer high enough... I went to a junk yard and got a dimmer switch.. I put the switch in and everything worked fine.. I then started my truck and turned the headlights on and something blew.. It wasnt a fuse bc i checked all of them... Now Im back to where I started from.. Nothing dims when I turn the headlights on... Could it be the switch stalk? Someone please help!!!
post #5 of 7 Old 05-31-2006, 02:33 PM
Quoted: 0 Post(s)
Sounds like it's over charging (the alternator) and causing things to pop.
Should be quick and easy to check the charging voltage.....just to be safe.
Verba ita sunt intelligenda ut res magis valeat quam pereat
Veritas aequitas.
ProBuilder is offline
post #6 of 7 Old 05-31-2006, 08:39 PM
Bring On The MUD!!!!!
Geius Maniacal's Avatar
Quoted: 0 Post(s)
you most likely have a short in the wire somewhere. at one point my dash lights, visor lights, running lights, and tail lights didnt work because the wire running to one of the running lights got worn through and it was shorting on the body. no fuses blew btw.
Cam
!!!SOLD!!! '83 SR5 w/ Cummins 4BT Turbo Diesel *Under Cons.* 6in Susp. and 3in Body lift on 35's
'99 Dodge Ram 2500 5.9L Cummins BD Super-B, CDT2, Custom 47RE, Adrenaline w/ Pulse, BD Hot Rod VP44, Airdog 165, BD XXX-Pulse 125's, Isspro EV2's
Geius Maniacal is offline
post #7 of 7 Old 05-31-2006, 11:19 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Is there any way to find a short without tracing every wire down??? I sure hope so... Thanks
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
