coolant temperature sensor
My 95 22re truck acts like it is not getting the correct fuel air mixture when i start out of a morning. It runs like i am dragging an anchor until it warms up. I have done the works as far as tuning it up. Does this sound like a the coolant temperature sensor not working properly? I was told that the sensor was located behind the thermostat housing. That is where the water temp. sending unit is located. Is that the same as the coolant temp. sensor. The wiring diagram says that the coolont temp sensor has a green and blue wire and the temp. sending behind the themostat has a green and yellow wire. Does anyone out there know anything about this animal. Thanks very much, D.T.
