Diagnostic Port - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 2 Old 02-17-2017, 07:00 AM Thread Starter
Yoda: Small & Green :-)
T-Yoda Enthusiast's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Diagnostic Port
Hello folks,
Been a while, but I figured I'd share a task I recently did to my yota from a squirrel invasion I had here a few months back.
Seems as though I didn't drive the truck enough and a bunch of hoodlum squirrels decided to take over. Luckily, the truck didn't burn down as I drove it with this mess under there without even knowing it was there, until I smelled some smoldering leaves when I got out of the truck.
Anyone else have this issue ?
Wife says to put a bag of used cat poop litter under the hood to discourage them. Doesn't sound safe to me...
lol
Found a 4 runner with the same diagnostic port, in a boneyard, and swapped it over. You can see that I had to clean out the junk grease in the new one after I pulled all the wires out of it. My aluminum sandwich wrap worked well for a while as the squirrel stole the cover off the port.. Started to break the original squirrel port apart with my dremmel. Some suggested I use the lisle tools to remove the pins, but I had more fun using my dremel as I have wanted to use the new tool heads for a while now.
Took about an hour and a half start to finish.
Click image for larger version
ID:	98122   Click image for larger version
ID:	98130   Click image for larger version
ID:	98138   Click image for larger version
ID:	98146   Click image for larger version
T.
94 SR5 Extended Cab, 3.0L, 5 spd manual, Spray on liner, Leer Cap (god forbid!), Class 4 hitch w/ 7 pin connector, HD front sway bar, Air Bag Load leveler in rear .....and a 2003 Sequoia SR5
T-Yoda Enthusiast is offline
post #2 of 2 Old 02-17-2017, 07:03 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
More pics.
Went through each pin, and inserted in the same location on the new (used) connector, as the 4 runner had different locations and wiring than my hilux
Fun project. back to OEM
ID:	98162   Click image for larger version
ID:	98170   Click image for larger version
ID:	98178   Click image for larger version
ID:	98186   Click image for larger version
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
