Tire Help - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
 1Likes
  • 1 Post By fourwd1
post #1 of 6 Old 03-14-2017, 06:29 PM Thread Starter
'93 Toyota Pickup 4x4
Quoted: 0 Post(s)
(Thread Starter)
Tire Help
Does anyone know the largest off road style tire you can fit on stock 15" six bolt pattern rims?
a.c.phillips is offline
post #2 of 6 Old 03-14-2017, 07:07 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 280 Post(s)
You need to give us a few more parameters.
You can fit a 40"x14.5"x15" tire on a 15" rim, or a 28"x6.0"x15" tire.
There's other factors we need to know to help you better.
Like is the suspension stock or lifted? if so how much?
What's the width of the rim?
The offset and backspacing?
beerhunt likes this.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is online now
post #3 of 6 Old 03-14-2017, 09:01 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Stock suspension. 4wd.
I'm unsure of the width of the rims, however they're stock 4runner rims from '93.
I'm looking for a beefier tire that won't slow down my 22re motor too much. Currently running 225/75 R15.
post #4 of 6 Old 03-15-2017, 07:56 AM
Senior TN Member
SC T100's Avatar
Quoted: 97 Post(s)
You may have better luck discussing it with the Pickup folks as you don't have T100. Otherwise I'd say 31x10.5R15s would probably be the biggest you'd want to deal with if you aren't going to re-gear. Again, I'd check the Pickup section...they probably have a lot more information than us.
'97 Extra Cab 3.4 4x4 5sp 102K and counting...
Aisin hubs, Marlin shifter bushings, a few fellow TN member mods, and lots of elbow grease.
SC T100 is offline
post #5 of 6 Old 03-15-2017, 08:00 AM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 464 Post(s)
Welcome to the forums!
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is offline
post #6 of 6 Old 03-16-2017, 07:28 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 280 Post(s)
Ok, you can run up to a 33" tire with minimal loss of power and mpg.
With a stock suspension a 31" tire is about as big as you can fit.
89 4Runner - stock
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
Tags
22re , pickup , pickup truck , tires
User Tag List
Linear Mode Linear Mode
Back
