Torque spec - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 4 Old 03-15-2017, 06:00 PM Thread Starter
Arthur
Quoted: 1 Post(s)
(Thread Starter)
Torque spec
Hello New to TN,
Working on replacing valve cover gaskets on my 3.0L V6 ; 92 Toy Trk.My manual says Torque place at 52 ft/lbs. Lookin at other post should be at 4.4lbs.BTW a Toy mechanic stated it should be hand tight.Can anyone give me the correct answer.Thanx
Arthur Gacad is offline
post #2 of 4 Old 03-15-2017, 06:27 PM
sdspeed's Avatar
Quoted: 175 Post(s)
Originally Posted by Arthur Gacad View Post
Hello New to TN,
5.4 lbs ft
most in the manual are stated in inch lbs. Valve covers are very thin and crack easily. I used 5 lbs since I hadn't had my torque wrench calibrated in a long time.
Scroll thru this page.
https://www.yotatech.com/f116/3vze-torque-specs-191652/
sdspeed is online now
post #3 of 4 Old 04-20-2017, 08:52 PM
Quoted: 0 Post(s)
Hey I'm a new member here and I have the parts to replace my valve cover seal on my 4 cyl. 5 spd 92 Toyota Pickup. Do you have any quick tips?
Reapercat2401 is offline
post #4 of 4 Old 04-20-2017, 11:09 PM
Quoted: 0 Post(s)
It one of the easiest DIY you can do on the trucks. Just make sure you tag all lines or take a picture. I would also replace the * and rubber grommet ( * forgetting the name of it, it's the one way vent that sits in the middle of the valve cover). It may be good but its cheap to replace and the grommet get old and brittle
sanddirt is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
