Blown motor/engine? - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 1 Old 03-16-2017, 10:38 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Blown motor/engine?
Hi:
This is my first post on this forum. I do not have much mechanical skills in repairing toyota pickups. However, I am willing to learn and try to resolve the issues on my 1992 Toyota Pickup base cab with 22RE 2.4L engine, approximately 175,000 miles.
Here is the problem or problems:
When started the pickup, a rattling noise at idling and the noise level rattling sound decreased as I accelerated the gas. Going to the store and there was little power when acclerating. Feels like the toyota pickup is losing power/compression and finally died on me while driving.
Now the pickup does not turn over at all, nothing!! I feared I might have blown the motor and I am not sure what to do. There is some water in the engine crankcase. Do I need to replace the motor/engine? If so, what are the components of the engine do I need to replace? Valve cover, head, engine block, water pump, oil pump, valve guides, timing chains, etc.? What parts on the Toyota pickup can be save and/or use for? I don't want to fall in a trap where buying parts are not needed and ending up wasting money on parts. I am not sure of where to start, either.
These are things I have done so far a few days ago before the toyota finally will not turn over as mentioned above:
1992 Toyota pickup 22re engine 2.4L manual transmission 5 speed
Toyota pickup knocking sound on the engine:
Bad valve lifter?
bad rod bearing?
push Rod bent?
connecting rod bad?
1. Noisy, vibration, rattling issues. Need to find exact noise location and its solution to this issue. I already removed and replaced valve cover gasket.
2. Valves adjustments near the arm rocker had been correctly gapped.
3. Water pump, oil pump and its gaskets are good. No oil or water/coolant leaks.
4. Timing chain is correct on TDC (2 of those), Top Dead Center.
5. Could be timing chain valve guides near the timing chain be worn out and need to be replace.
6. Could be timing chain itself is worn out, loose, etc.
7. Could be oil issues: Replace oil filter and new oil to see if that does the trick in stopping the rattling noise. Too late already for that now.
I did some web searching particularly on ebay in regards to the engine. Some are just engine blocks only. Others are engine repair kits which consist of timing chains replacement kits along with oil and water pump, valve guides, gaskets, etc.. What about a complete engine with engine bloc, cylinder heads, valves, pistons, valve covers, etc? Should that all be replace as well? I also heard valve cover gets warped, too. What about engine compression or the lack of it?
I need to sort out what parts are needed, while other parts can be save and use on the Toyota PIckup
Does anyone out there have similar experiences and willing to share?
Any comments/feedback/advice is greatly appreciated.
NewbieLearning is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
