92 toy pickup high speed bucking with powerloss - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 9 Old 03-17-2017, 08:46 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Unhappy 92 toy pickup high speed bucking with powerloss
got a 92 Toyota 5sp 22RE. at my end and some what of a mechanic. I have replaced distributor, coil, ecm, and ignitor. checked wire continuity from ignitor to ecm. when i drove truck for 5 miles under 55mph no troubles (was not easy on it) then rode it at 80mph for about a mile. then started bucking with CEL flashing. pulled codes 12 and 14. i have checked fuel pressure regulator. fuel pump 1 year old. looking for any help. have read in the forums and not found anything that matches what i am have problems with. idles fine no hesitation in take off.
edsfastfury is offline
post #2 of 9 Old 03-18-2017, 10:11 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 295 Post(s)
Bucking while accelerating can be caused by a clogged fuel filter, you may want to replace it.
Have you looked into solving the 12 and 14 error codes?
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 9 Old 03-18-2017, 10:36 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i am trying to repair codes. the bucking does it at a steady speed not when you are accelerating
post #4 of 9 Old 03-18-2017, 10:56 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 295 Post(s)
Does it stop when you let off of the gas pedal?
89 4Runner - stock
fourwd1 is offline
post #5 of 9 Old 03-18-2017, 03:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
at first it would not. I have replaced fuel filter took it for a drive between 70-80mph after about 17 miles it bucked and shut off with me just gave me code 14 when I got back home. so I have ordered a new ignition control mod. thinking it is breaking down from heat and losing signal. just put one on last week but the code never went away. I have checked wires to ecm they all showed good.
post #6 of 9 Old 03-20-2017, 02:15 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 295 Post(s)
Yeah, could be that.
May be worth replacing the coil as well.
89 4Runner - stock
fourwd1 is offline
post #7 of 9 Old 03-21-2017, 09:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
installed my second ICM. ran just as bad. cleaned out the cat converter and reinstalled. ran better but still bucked and shut off on me. don't seem to like to rev past 3000 rpm. going to remove the bed and check the fuel tank for trash/water. the coil is only 1 week old.
post #8 of 9 Old 03-23-2017, 09:10 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
ok here we go. checked fuel pressure it was a okay. so I figured I would replace the worn out timing chain and who would have known that fixed my problem. who would have thunk that.
post #9 of 9 Old 03-24-2017, 07:44 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 295 Post(s)
Wow.
Had it jumped a tooth?
89 4Runner - stock
fourwd1 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
