flushing slave cylinder - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 07-17-2006, 08:29 AM   #1 (permalink)
grease monkey
99mustang232's Avatar
View 99mustang232's Photo Gallery
i want to flush the fluid in the slave cylinder and resovior any tips or do i treat it like a brake job? should i replace the slave cyldiner, hell it is only like $10-$15?
1994 Toyota Pickup Ext. Cab
2.4L I4 22RE, 5speed, 2x4
99mustang232 is offline   Reply With Quote
Old 07-17-2006, 08:59 AM   #2 (permalink)
Languishing in Maryland
TNRabbit's Avatar
Gameroom cash: $295260
View TNRabbit's Photo Gallery
just like bleeding brakes. Be sure you use a clear hose in fluid to prevent drawing back air into the system.
TNRabbit
STOCK '94 DLX XtraCab 4x4, 5 spd, 3VZE, 270,000 mi.
TNRabbit is offline   Reply With Quote
Old 07-17-2006, 09:22 AM   #3 (permalink)
TNRabbit's Avatar
Post some pics; maybe someone here has a fix....
TNRabbit
Old 07-17-2006, 11:03 AM   #4 (permalink)
Banned
subliminaltrips's Avatar
View subliminaltrips's Photo Gallery
sup mustang?, long time no see.
id personally id replace it. while you have the lines disco dump some fluid in the resivior and pump the pedal a time or two and it will flush out the lines.
subliminaltrips is offline   Reply With Quote
Old 07-17-2006, 12:00 PM   #5 (permalink)
View TurboJim's Photo Gallery
Unless it is leaking there would be no advantage to replacing it. If it has not been flushed out in awhile (if ever) then it will take several flushings before the fluid remains clear.
TurboJim is offline   Reply With Quote
Old 07-18-2006, 12:16 AM   #6 (permalink)
grease monkey
what's up buddy? just been helping a friend with a project 408 dakota
OBDII codes Phi Hardcore Tech and Competition 13 07-02-2012 08:09 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
