My 1992 Toyota pu, 2.4 cyl. when I attempt to start the truck, I put the key in and it won't turn. If I jiggle it some sometimes it turns and other times it does not. I went to the dealer and had a new key made and that does not help..I sprayed it with some wd40 and that did not help, except for the mess it made. I am not sure what I can do. Is it time to replace the ignition and key? Thanks
:thumbup: I got the new key, hit the cylender behind the actuall key thingy, and what do you know. It turned and it started just fine. So, maybe that can help someone. I love my little yota with 169000 miles.
I had a 1984 that got so bad I had to replace the ignition. It's easier to do it now while you can at least get the key to turn instead of waiting until it won't turn at all.
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
588.4K members
Since 2001
