FAQ - Timing Chain, Engine Codes, Surging Idle, Steering Noises, ECT... - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
 3Likes
post #16 of 64 Old 05-25-2008, 01:47 AM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
Originally Posted by chrismacias2001 View Post
i have a 93 toyota truck, and just finished fixing the idle surging, but the engine idlea at about 2600 rpm, the idle screw is adjusted all the way, and still idles at 2600 any suggestions??
take a peek at the throttle body and see if it is clean, new air filter helps also. make sure the throttle linkage stop is adjusted so the throttle body isnt open. check for all moving parts around the throttle body. i hope that helps because after doing that, i achieved in lowering the idle RPM, and then after cleaning, i have a more responsive and cleaner feel on the gas pedal
94 RN93 | *dead* | W58 | 2WD8"V6 | FX-R3.0 5000K 35W| 18x10.5 295/30/18
95 JZA80 | V160 | HKS Intake, Hipermax IV GT, & 4" Ti | RMS SS 3" DP | Bride Stradia | Nardi
89-95 Hilux Massive Truck Info
IronNam is offline
post #17 of 64 Old 06-14-2008, 08:41 PM
FoxRacin17's Avatar
Quoted: 0 Post(s)
anyone have a pic of the steering stops?
Go Gators!
FoxRacin17 is offline
post #18 of 64 Old 07-27-2008, 11:12 AM
Kagato91's Avatar
Quoted: 0 Post(s)
The idle is controlled by the "Idle Control Valve" inside the throttle body.When it gets clogged up by carbon from recirculated exhaust gas (thanks Toyota engineers) it tends to stick.A good cleaning should remedy this.There are throttle body and intake manifold cleaning kits available.Using such a kit can free up several ponys plus add to throttle response.
Kagato91 is offline
post #19 of 64 Old 07-29-2008, 07:10 PM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
=] basically what i put, but thanx for sharing the info about the kits. yesh cleaning the manifold and TB will do alot to increase power. i will be cleaning the manifold sometime soon. i will try to get ahold of a camera to show you guys how it goes. if not, i will note parts that might get in the way and how to solve anything that goes on. happy trucking you all
IronNam is offline
post #20 of 64 Old 11-24-2008, 02:56 AM
JALEWI7475's Avatar
Quoted: 0 Post(s)
I have a question for anyone out there
JALEWI7475 is offline
post #21 of 64 Old 11-24-2008, 03:04 AM
JALEWI7475's Avatar
Quoted: 0 Post(s)
I own a 89 pickup with a bone stock 22-re it has almost 190,000 on the truck. Here is my problem the truck shakes like crazy!!!!!!!!!!!!! now here is some more info. The rear end went out in it last winter which is when it started to vibrate. so I replaced the rear end in it with one from a junkyard pretty simple fix. The truck still shakes. I though it was from the rear end so I went down to the shop and asked my mechanic what could it be? he said try flipping your drive shaft 180 degrees so I did and it still vibrates I notice it everywhere in my steering wheel and it shakes my ash tray out it rattles my sliding rear window and it does it pretty much at all speeds not enough to scare you but when I am accelerating from right around 40 to 55 mph is when it gets a little hairy. any ideas or suggestions? such as new tires clutch balance the drive shaft or new ball joints something thank you
post #22 of 64 Old 11-24-2008, 03:05 AM
JALEWI7475's Avatar
Quoted: 0 Post(s)
also the rear end in the truck is a 4:10 right? what if by chance I put in a different gear ratio would that affect it? and how can I tell if it is a 4:10 rear end?
post #23 of 64 Old 12-10-2008, 10:44 PM
Kagato91's Avatar
Quoted: 0 Post(s)
About 90% of all the trucks came out 4:10.If it's auto trans or factory oversize tires or both you might wonder.My truck shakes alittle.Shocks,broken belts,heavy ply tires or bad u-joints can cause vibrations.
1991 4x4 22RE 5spd 294,2xx miles.
96 4Runner wheels
ENGINE:original unrebuilt
TRANSMISSION:original w/original gears.Has new bearings and seals as of 254k.
Kagato91 is offline
post #24 of 64 Old 12-14-2008, 02:35 PM
JALEWI7475's Avatar
Quoted: 0 Post(s)
thanks man I appreciate it very much.
post #25 of 64 Old 01-16-2009, 05:38 PM
Quoted: 0 Post(s)
my 91 22re pickup has an idle problem when the brakes are applied, could someone help me figure out what the problem is?
yotaspeed is offline
post #26 of 64 Old 01-17-2009, 06:39 PM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
cold weather outside, 30-40 degrees, varies around 50 sometimes, idle is weird, after engine gets pretty damn warm, and im on Drive and i stop at intersection, on some occasion motor shuts off
IronNam is offline
post #27 of 64 Old 01-17-2009, 06:44 PM
Quoted: 0 Post(s)
Isn't the typical cause of rough idle with brakes applied the brake booster? If the vacuum line to the booster is pinched closed does the problem persist?
desconhecido is offline
post #28 of 64 Old 01-19-2009, 12:19 PM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
mine use to be fine with the brakes applied AND in the reverse on my automatic... not sure what is making it so cranky.
i'll attempt to spray some carb cleaner in my TB later...
IronNam is offline
post #29 of 64 Old 01-19-2009, 12:20 PM
Saving lives
IronNam's Avatar
Quoted: 3 Post(s)
btw it also happens when im going 70ish on the highway, get on Off ramp, then at the first stop intersection, itll shudder really badly then shuts off
IronNam is offline
post #30 of 64 Old 01-22-2009, 11:04 AM
Quoted: 0 Post(s)
mine has not shut off but it seems to do it after high speeds or if its kept in high revs for an extended amount of time. it has new spark plugs and a fairley new air filter. ive cleaned the throttle body numerous times. it only does it in cold weather
The Following User Says Thank You to yotaspeed For This Useful Post:
Cityman1 (12-14-2013)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
