FAQ - Timing Chain, Engine Codes, Surging Idle, Steering Noises, ECT... - Page 5 - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
 3Likes
post #61 of 64 Old 03-08-2015, 11:36 PM
Quoted: 0 Post(s)
my 89 toy p/u when its cold out, 60 deg or below, below 40 deg, idle surge when I hit the brakes, let off brakes, goes to high idle, let it sit 10 mins, idles great, touch brakes and it does it again.
TK-yota is offline
post #62 of 64 Old 03-27-2015, 11:32 AM
Quoted: 0 Post(s)
Alright guys need some help, got 92, 3.0 v6 new coil, fuel pump everything seems to be operating correctly, I can crank the truck, while cold it runs great, but after the motor gets warm or runs a while, whether idling or goin down the rd, it just cuts off and a couple fuses in the box in the cab on driver side are pretty warm, the truck had been under water and up above that box, is there a good chance the fuse box is no good any more and it's just Heating up due to corrosion ?
BigHoss89 is offline
post #63 of 64 Old 04-11-2015, 09:05 AM
Quoted: 3 Post(s)
Hey guys,
I've just replaced my timing chain and guides, and everything that goes with it. One of the main goals was also to fix a slight oil leak right up the top of the timing case just above the water pump. Now, while the case was off, I made sure the section of head gasket that is free'd up was stuck to the head with gasket goo, then while I placed the timing case back on there was nothing that could possibly get through.
Left it for a few days to dry before getting everything back on and putting oil etc back in. Started her up, did the timing, and sure enough, the little son of a bitch of an oil leak is back in the same spot. Does anyone else have this problem with the 22r???? How do I fix it :/
tracks94 is offline
post #64 of 64 Old 06-05-2015, 03:44 PM
Quoted: 0 Post(s)
I have a problem right now where engine timing is low and needs to be forwarded. Idle is low when not giving gas. But as mechanic turned the idle screw up half a turn, didn't fix the problem. Going to have him forward the engine timing. Problem started as he changed the engine timing to pass smog test.
gmantypk is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
