FAQ - Timing Chain, Engine Codes, Surging Idle, Steering Noises, ECT... - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
 3Likes
post #1 of 64 Old 10-03-2006, 05:18 PM Thread Starter
Bring On The MUD!!!!!
Geius Maniacal's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Exclamation FAQ - Timing Chain, Engine Codes, Surging Idle, Steering Noises, ECT...
Links, Advice, Help:
Post anything concerning our Frequently Asked Questions on this Forum.
Please search this thread for questions you may have before posting in the main forum. This will help us to keep the forum clean and reduce the amount of repeated threads. Thank You.
Cam
!!!SOLD!!! '83 SR5 w/ Cummins 4BT Turbo Diesel *Under Cons.* 6in Susp. and 3in Body lift on 35's
'99 Dodge Ram 2500 5.9L Cummins BD Super-B, CDT2, Custom 47RE, Adrenaline w/ Pulse, BD Hot Rod VP44, Airdog 165, BD XXX-Pulse 125's, Isspro EV2's
Geius Maniacal is offline
post #2 of 64 Old 10-03-2006, 05:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Timing Chain: (Thanks to DCM)
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Surging Idle: (Thanks to Mushroom_Toy)
Most of the time you just need to set your idle. You can do this by turning the black screw on the Throttle body (im pretty sure its right there). Just have someone step on the brake while the truck is running and turn the screw till it stops, make sure idle is not to high or low though. If this isnt the prob. then more than likely its vaccum related.
Here's a pic of the screw if you need it.
Cam
post #3 of 64 Old 10-03-2006, 05:41 PM
Senior TN Member
shoes1382006's Avatar
Quoted: 0 Post(s)
3vze and 22re engine info-------->http://www.babcox.com/editorial/ar/ar400108.htm
89' Yota 2WD 3VZ-TTE With Flows, Intake, Underglow, Black Paint Job, Black rims, Dual Stereo Deck n Lotz More By Clicking here... http://www.cardomain.com/ride/437849/
http://Projektnorkal.freeforums.org
shoes1382006 is offline
post #4 of 64 Old 10-04-2006, 06:31 AM
Senior TN Member
Quoted: 0 Post(s)
Creeking Front End
Creeking front end noises when the wheels are turned all the way are often attributed to the steering stops. There are plastic caps that come on them originally that tend to wear off over time. Once that happens, the metal on the stops rusts and they rub against each other when the wheels are cut all the way, especially when driving over bumpy terrain.
The plastic caps can be replaced but don't always last. The easiest solution is to simply apply grease, Never Seaze, Anti-Seaze, etc to them. I usually do it whenever I change my oil.
"The normal make a living. The deranged make history." -Christopher Titus
maxpower_hd is offline
post #5 of 64 Old 10-04-2006, 03:49 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
These are 40 Toyota used parts suppliers and junk/bone/wrecking/salvage/recycling/dismantling/scrap yards: (Thanks to Sidney)
Toy Works 4WD Technology
Shane Lawrence
County Road 109
Orangeville,Ontario L9V 1A1
Canada
Ph: (519) 938-9844
Toy Works
K C Signs
Portugal Cove,NL A0A 3K0
Canada
Ph: (709) 895-6123
South Island Imports
2053 Balsam Rd
Nanaimo (South),Vancouver Island,BC V9X 1T5
Canada
Ph: 1-877-753-1119
Ph: (250) 753-8019
http://www.southislandimports.ca
E-mail:southislandimports@shaw.ca
Toyota 4x4 center (AllToy)
Kami 4X4
Tony Carr
427 Mount Paul Way
South Kamloops,BC V2H 1A7
Canada
Ph: (250) 851-4480
Precision 4X4 Center (www.****************.com) (some pickup diesel parts)
Corey Maidment (slacker)
1280 Commercial Way Unit 109
Penticton,BC V2A 3H5
Canada
Ph: (250) 493-9473
Fax: (250) 493-9474
http://www.****************.com
http://www.geocities.com/motorcity/flats/1738
http://www.members.shaw.ca/slacker502
info@****************.com
support@****************.com
sales@****************.com
Corey CJ@****************.com
webmaster@****************.com
slacker501@shaw.ca
coreymaidment@netscape.net
HonDaToy Automotive Ltd
14325-114 Ave
Edmonton,Alberta T5M 2Y8
Canada
Ph: 1-800-661-3957
Ph: (780) 453-6711
http://www.hondatoy.com
E-mail:parts@hondatoy.com
Yota Ray's Toyota 4X4 Truck Parts
1808A17 th Ave S.E
Calgary,Alberta T2G 1K4
Canada
Ph: 1-877-273-7322
Ph: (403) 2738137
Fax: (403) 2638185
http://www.yotarays.ca
E-mail:office@yotarays.ca
Adamant Service Center
Box 70,Hagget Rd
Adamant,VT 05640
USA
Ph: (802) 233-1488
E-mail:asc@drbs.com
Woodward's Used Toyota Parts
3059 Main St
PO Box 236
Summneytown,PA 18084
USA
Ph: 1-800-646-4386
Ph: (215) 234-4386
Fax: (215) 234-8035
Lowells Toyota Parts
111 Mechanic St
Lexington,KY 40507
USA
Ph: (606) 233-1173
Tallant Brothers (Toyota/Honda/Nissan)
Jimmy & Greg
4695 Oak Grove Circle
Cumming,GA 30130
USA
Ph: 1-800-635-0351
Ph: (404) 887-5214
Fax: (770) 889-7244
Graham's Automotive
958 HWY 202
Calera,AL 35040
USA
Ph: (205) 668-3441
http://www.grahamsauto.com
E-mail:jon@grahamsauto.com
Victor's Off Road Engineering
Victor
4646 Lonedell Road
Arnold (Saint Louis),Missouri 63010
USA
Ph: (636)296-6696
Toyota Heaven
6723 Oakcrest Dr East
Fort Worth/Kennedale,TX 76140
USA
Ph: (817) 563-1744
Ph: (817) 563-1754
E-mail:frs@toyohv.actual-america.com
A-1 Toyota Salvage
302 New Laredo Highway
San Antonio,TX 78211-1908
USA
Ph: (210) 921-0031
Yota Yard
Jim/Nancy Wales
3134 Walnut St
Denver,CO 80205
USA
Ph: (303) 292-5078
Fax: (303) 308-0430
http://www.yotayard.com
E-mail:nancy@yotayard.com
Toyotas "R" Us
7730 CR 150
Salida,CO 81201
USA
Ph: (719) 539-7733
Toyota Salvage
3224 S 40th St
Phoenix,Arizona 85040
USA
Ph: 1-877-807-4314
Ph: (602) 437-1222
http://www.toyotasalvage.com
Mazda-Toyota Auto Recycling (also Nissan)
Richard
3611 NW Marine Dr
Troutdale,OR 97060
USA
Ph: 1-800-628-0918
Ph: (503) 667-6818
Fax: (503) 669-7810
http://www.maztoy.com
E-mail:sales@maztoy.com
The Toyota Man
3610 NE Columbia Blvd
Portland,OR 97211
USA
Ph: (503) 775-3345
E-mail:thetoyotaman@earthlink.net
Ali's auto (Tacoma,Tundra & T-100)
1340 Idaho St
Pt.Orford,OR 97456
USA
Ph: (541) 332-0333
Nix 99
13718 Mukilteo Speedway
Lynnwood,WA 98037
USA
Ph: 1-800-782-0682
Ph: (425) 743-2881
http://www.nix99.com
E-mail:parts@nix99.com
All Toyota Auto Recycling
27865 SR 410
East Buckley,WA 98321
USA
Ph: 1-800-829-9766
Fax: (360) 829-1852
E-mail:dliy@aol.com
Kings Honda & Toyota Auto Recycling Inc
9101 Martin Luther King Jr.Way South
Seattle,WA 98118
USA
Ph: (206) 723-9633
Fax: (206) 722-1599
http://www.kingshondaandtoyota.com
E-mail:parts@KingsHondaAndToyota.com
All Japanese Auto Recyclers
11301 Dismantle CT
Rancho Cordova,CA 95742
USA
Ph: 1-888-608-PART
Ph: (916) 635-2345
Fax: (916) 635-8100
http://www.alljapaneseautoparts.com
E-mail:alljapanese@jps.net
Toyota Truck & Auto Recycling (TAP Recycling)
11337 Dismantle CT
USA
Ph: (916) 631-7100
Toyota Engines By CT Engineering
3457 Fitzgerald Rd
USA
Ph: (916) 852-1032
All Toyota Used Parts
3370-A Sunrise Blvd
USA
Ph: 1-800-557-8674
Ph: (916) 853-7242
Fax: (916) 635-5724
http://www.alltoyotausedparts.com
E-mail:webmaster@alltoyotausedparts.com
Al
3636 Omac Circle
USA
Ph: 1-800-765-7100
Toyota Truck Parts
3440 Recycle Road
Sacramento,CA 95742
USA
Ph: 1-866-292-9495
Ph: (916) 853-0833
http://www.toyotatruckparts.biz
E-mail:service@toyotatruckparts.biz
Capitol Import
4071 Happy Lane
Sacramento,CA 95827
USA
Ph: 1-800-259-5529
Ph: (916) 366-7470
http://www.capitolimport.com
E-mail:sales@capitolimport.com
The Toyota Connection
Ryan
2620 W. Capital Ave
West Sacramento,CA 95691
USA
Ph: 1-800-221-8696
Ph: (916) 371-7764
Fax: (916) 371-7037
Toyotas Only
11540 Hart St
N. Hollywood,CA 91604/5
USA
Ph: 1-800-835-2444
Ph: (818) 765-0322
Ph: (818) 765-0323
Fax: (818) 765-8013
http://www.toyopartsonly.com
E-mail:webmaster@toyopartsonly.com
LA Toyota Auto Dismantling Inc
11115 Tuxford ST
Sun Valley,CA 91352
USA
Ph: (818) 768 4142
Fax: (818) 768 8442
D & T Used Parts/DNT Auto Dismantling (Datsuns and Toyotas)
8970 Bradley Ave
Sun Valley,CA 91352 or Pacoima,CA 91331
USA
Ph: (818) 768-4666
Toyota Truck & 4X4 Dismantlers
991 Berryessa Road
San Jose,CA 95133
USA
Ph: (408) 436-7890
Fax: (408) 436-9779
Bernie's Auto Dismantling
1008 Vreeland Ave
Wilmington,CA 90744
USA
Ph: (310) 518-2685
California Mini-Truck Dismantlers
4002 State Street
Montclair,CA 91765
USA
Ph: (909) 622-1381
Fax: (909) 623-3240
http://www.calminitruck.com
E-mail:info@calminitruck.com
Minit Truck Dismantling Center
1700 Newton Avenue
San Diego,CA 92113
USA
Ph: 1-800-827-1970
Ph: (619) 233-3884
All Toyota Lexus Auto Recycling
Chuck
1060 Otay Valley Rd
San Diego,CA 92154-5615
USA
Ph: 1-877-778-6968
Ph: (619) 661-0055
E-Mail:scrapdaddy@cox.net
Cam
post #6 of 64 Old 10-04-2006, 04:47 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
22R Series tech data sites along with other Toyota engines: (Thanks to Sidney)
http://www.babcox.com/editorial/ar/ar119838.htm
http://www.toyotaperformance.com/4_cyl_tech.htm
http://www.lcengineering.com/TechNotes/TechNote48.htm
http://www.toysport.com/Technical%20...tech_notes.htm
http://www.off-road.com/toyota/tech/...toy_motor.html
http://www.off-road.com/toyota/tech/other/4_dts.html
http://www.4x4wire.com/toyota/faq/parts
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.toyota-mods.org/engines.txt
http://www.toyotagtturbo.com/engines2.html
http://www.engnbldr.com/ToyotaHotlicks.htm
http://www.bitwalla.com/cruisers/info/engines.html
http://www.off-road.com/tlc/faq/engine.html
http://www.jnc.farpost.com/toytech.html
http://lcengineering.com/TechNotes.htm
http://www.buschtaxi.net/de/01info/motoren.html
http://www.landcruiser.hu/motorok.html
http://www.toysport.com/Technical%20...nsmissions.htm
http://en.wikipedia.org/wiki/Toyota_transmissions
About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered.
To pull the ECU codes:
All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it:
http://autorepair.about.com/library/...bl-dtcs-36.htm
http://autorepair.about.com/library/...bl-dtcs-53.htm
http://autorepair.about.com/library/...bl-dtcs-71.htm
http://autorepair.about.com/library/...bl-dtcs-90.htm
http://www.off-road.com/toyota/tech/codes/index.html
http://lcengineering.com/TechNotes/TechNote12.htm
http://lcengineering.com/TechNotes/TechNote13.htm
http://www.mad-mechanic.com/toyota/t...tml#obtaincode
http://www.freewebs.com/th3duke/22RE-ECU.mht
http://www.troublecodes.net/Toyota
http://members.igateway.net/~pscott/enginecodes.html
http://www.autobook.co.kr/data_links...uble_codes.htm
http://www.autoshop101.com/forms/h27.pdf
http://www.showmesome.info/hilux/inf...E/Page0096.htm
http://www.efisakh.narod.ru/at_toyota.htm
http://www.usatransdoctor.com/foreigntoyota.htm
Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio.
Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Clymers,Bentley and Toyota repair books.
There is also free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiB...pair_guide.jsp
FSM (factory service manual)can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton,CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
For scanned pages of factory service manuals for other engines:
Cam
Last edited by TrailDust; 07-13-2009 at 01:57 PM. Reason: Factory service manual links deleted.
The Following User Says Thank You to Geius Maniacal For This Useful Post:
dusterp94 (02-28-2012)
post #7 of 64 Old 10-11-2006, 12:26 PM
Senior TN Member
Quoted: 0 Post(s)
Removing PCV Valve
I don't know if this is an issue worthy of a sticky but I have read a couple of posts about destroying the plastic/rubber gromet when removing the PCV Valve. I had to remove mine the other day and was able to place the head of a small ball peen hammer next to the valve on the rocker cover. Then I put a pair of pliers on the valve with the front of the pliers setting on the head of the hammer, for leverage. I was able to sort of pry the valve straight out of the gromet without it getting cocked in the hole, which is why I think they break. Kind of like you would do to get a large nail out of a piece of wood by placing a block under the head of the hammer before pulling the nail.
post #8 of 64 Old 10-11-2006, 09:58 PM
DCM
One with the farce
Quoted: 5 Post(s)
To add to this, the grommet is often too brittle to remove. When the PCV valve is removed and the grommet breaks, the pieces fall into the baffle inside. This makes it necessary to remove the valve cover, take off the baffle and clean out the pieces, then reassemble the whole works. It's best to get a new grommet before you remove or change the PCV valve.
DCM is offline
post #9 of 64 Old 12-24-2006, 09:33 AM
Banned
subliminaltrips's Avatar
Quoted: 0 Post(s)
this is about the most in depth faq out there
Last edited by TrailDust; 07-19-2009 at 11:25 AM. Reason: Link to factory service manuals deleted.
subliminaltrips is offline
post #10 of 64 Old 03-02-2007, 08:17 PM
Lemon Jelly Donut
rivethed's Avatar
Quoted: 0 Post(s)
Vacuum diagrams
I have seen alot of requests on the threads fro the vacuum diagrams..... pouring throug my copy of my FSM, I have located the following pages:
Section EG2 (3VZ-E Engine) Page 142 (emission vacuum house routing and connections).
Section EG1 (22R-E Engine) Page 82 (emission vacuum house routing and connections for Federal and Canadian Models).
Section EG1 (22R-E Engine) Page 82 (emission vacuum house routing and connections for California Models).
For FSM's, Contact you rlocal toyota dealer, book store, or look to the top of this forum for link's
"These are my experiences, yours will vary!"
06 Taco AccessCab, 4.ohhhh, Prerunner Sr5
93 xtra cab "pig pen" (sold, /me pours the "red stuff" out in remembrance)
?? ISO the next project
rivethed is offline
post #11 of 64 Old 02-05-2008, 02:45 PM
Quoted: 0 Post(s)
I've a problem with my truck's idle, which I bought used. The adjusting screw is all the way down and the idle is still too high AFTER the engine reaches Operating Temperature. The idle fluctuates alternatively up/down if set higher and when the break pedal is depressed. By the way, I had the same trouble a few months back and it went away by itself. It just passed Smog Check and then started failing again.
1913_toy
1993_toy is offline
The Following 2 Users Say Thank You to 1993_toy For This Useful Post:
bro.betterley (09-12-2013), wgrumbley (06-10-2012)
post #12 of 64 Old 02-16-2008, 12:39 PM
Quoted: 0 Post(s)
same thing here
no leaks no codes like it shuts ingnition off for a second
cavedude is offline
post #13 of 64 Old 02-22-2008, 07:52 PM
dmb
Quoted: 0 Post(s)
I have got the same problem with my 1994 Pickup, but only when the engine is cold. When I start the engine the idle is at about 1600 for a short time, than it drops and fluctuates for about 7 minutes from 900 to 1200. After about 10 minutes drive (depends on the outside temp.) the idle stays at 800 and does not move at all, just as it should.
What is that, someone knows what to do??
dmb is offline
post #14 of 64 Old 02-29-2008, 11:31 PM
Quoted: 0 Post(s)
Just bought a t-100....where are the steering stops? thanks...
ossify is offline
post #15 of 64 Old 04-10-2008, 11:15 PM
chrismacias2001's Avatar
Quoted: 0 Post(s)
i have a 93 toyota truck, and just finished fixing the idle surging, but the engine idlea at about 2600 rpm, the idle screw is adjusted all the way, and still idles at 2600 any suggestions??
chrismacias2001 is offline
The Following User Says Thank You to chrismacias2001 For This Useful Post:
Bparkride1 (04-14-2013)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
