Do-It-Yourself Modifications - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 45 Old 11-11-2006, 05:36 PM Thread Starter
Pb
Surfing TN via iPhone
Pb's Avatar
Quoted: 0 Post(s)
iTrader Score: 15 reviews
(Thread Starter)
Exclamation Do-It-Yourself Modifications
Lowering Block Install/Shock Install/Middle Leaf Removal
Engine Mount Change
If you guys post some links to other good DIY threads here I'll take em and add em all to this first post and make big list. Post links in this thread, then I'll clean up the thread after the main list is completed.
Pb is offline
post #2 of 45 Old 12-23-2006, 06:29 PM
rookie
Quoted: 0 Post(s)
some dingleberry once acted like he knew a thing or two about a thing or two and posted crap about idler arms. what a douche.
http://www.toyotanation.com/forum/t171454.html
pee_cup is offline
post #3 of 45 Old 01-08-2007, 10:12 PM
Lemon Jelly Donut
rivethed's Avatar
Quoted: 0 Post(s)
this one I did on my place, but is open to the public for perusal:
http://www.dirtyworldoffroad.com/for...topic.php?t=11
And this one was useful to novice electicians adding lights to their toys:
http://www.dirtyworldoffroad.com/for...opic.php?t=112
"These are my experiences, yours will vary!"
06 Taco AccessCab, 4.ohhhh, Prerunner Sr5
93 xtra cab "pig pen" (sold, /me pours the "red stuff" out in remembrance)
?? ISO the next project
rivethed is offline
post #4 of 45 Old 02-23-2007, 12:34 PM
Quoted: 0 Post(s)
I know I'm new but I found this while searching, hope it can help someone
DIY body drop
http://www.fullsizechevy.com/forums/...d.php?t=134808
Joker6 is offline
post #5 of 45 Old 08-30-2007, 02:24 PM
Quoted: 0 Post(s)
none to show me how to swap the stereo to a new one ?
Im stuck as to how to get the old one out.
helpme is offline
post #6 of 45 Old 10-02-2007, 07:03 PM
vtyotapickup's Avatar
Quoted: 0 Post(s)
you talkin about tryin to take the factory radio out?
vtyotapickup is offline
post #7 of 45 Old 10-10-2007, 08:53 PM
Quoted: 0 Post(s)
any help on installing a front air locker in a 92 4x4,thinkin about it or goen to a straight axl any coments?
cptnchaos88 is offline
post #8 of 45 Old 10-28-2007, 05:51 PM
Quoted: 0 Post(s)
what is the intended use?
92PU4x4 is offline
post #9 of 45 Old 11-05-2007, 10:12 PM
Quoted: 0 Post(s)
as long as you have a welder and a torch doing a sas swap only takes a fiew hours. so i would recommend doing that.
klock'syota126 is offline
post #10 of 45 Old 11-22-2007, 09:03 AM
Quoted: 0 Post(s)
powertrax lock-right
I did a locker install on my 93 2WD 22-RE 5-Speed Reg. Cab Short Bed. I figured since I couldn't find any info here on it I would do a write up.
The locker is a Powertrax Lock-Right by richmond gear.
THIS IS HOW I DID IT! NOT HOW THE INSTRUCTIONS TELL YOU TO DO IT.
(so proceed with caution)
drain differential gear oil, reinstall the drain plug
block the front wheels, jack up the rear by the differential, use jack stands
unbolt the brake line hold down clamp closest to the hubs on both sides (12mm)
unbolt the 8 (four on each side) 14mm nuts that hold the hub/brake assembly/wheel onto the axle housing, pull the wheel/hub assembly/axle shaft as far out as the brake line will let you.
crawl under the truck and unbolt the drive shaft from the differential flange 4 bolts and nuts, I cant remember what size. they're either 12mm or 14mm, probably 14mm
You can either take the drive shaft out, or to prevent leaking from the transmission output shaft you can tie it up to the chassis. I used some tie-wire. remove the 10 12mm bolts that hold the third member onto the axle housing and pull out the third member, be careful, it has a good bit of weight to it.
If the carrier doesn't come out, the axle shafts aren't pulled out enough.
i used a angle grinder with a wire brush wheel to clean up the gasket surface
the locker comes with decent installation instructions.
some of the things I had to figure out myself despite having locker instructions and a Haynes manual
the ring gear has to be removed, mark its position on the carrier (silver sharpies work well) the retainer clips that prevent the ring gear bolts from coming loosened can be bent down with a screwdriver and a hammer then with the 17mm socket and a hammer the rest of the way, after reinstallation bend them back with some channel locks or other pliers. also line up the bolts and retainers in a line on the floor starting where you marked the ring gear/carrier position going clockwise so they all go back in the same hole. use a brass punch to get the ring gear off.
when removing the pinion shaft. the retainer pin has to come out of the hole in the "back", the one that isn't round you'll have to use a tapered punch to make the hole round so the pin can come out. then just punch the pin out from the other side.
I hope this helps someone be not as frustrated as I was while installing my powertrax
Driving! = I cant even tell it is there unless I am idling in a clockwise circle with my head out the window because thats the only was i can actually hear the ratcheting. and when I take off from a stop in the rain the rear end kicks out a little if I am too heavy on the throttle
brandon3155 is offline
post #11 of 45 Old 12-18-2007, 10:46 PM
Quoted: 0 Post(s)
Hey guys, new guy here. Any ideas or preferences on a push/bull guard on a (my) '89 pickup. Not sure where to look or what looks sharp. Ideas?
BlueYota is offline
post #12 of 45 Old 12-19-2007, 12:25 AM
Quoted: 0 Post(s)
3rd Generation smitty built
I have a 89 yota to and i just bought a Smitty built front bumper and it looks bad ass, i got the front and back for $150
post #13 of 45 Old 12-19-2007, 03:23 PM
Quoted: 0 Post(s)
Hey guys. Just bought this '90 pick-up 4x4 for my son and it came with 4" body lift. I want to do away with this and go with more of a traditional lift. I still want to get about 4" but want the body to get re-aquainted with the frame. Any tips?
vonhopper is offline
post #14 of 45 Old 12-19-2007, 06:22 PM
Quoted: 0 Post(s)
Kloks, im looking for a push bar-ish type with the ability to add lights and eventually a winch? any detailed thoughts/ places to go?
BlueYota is offline
post #15 of 45 Old 12-19-2007, 08:09 PM
Quoted: 0 Post(s)
3rd Generation
go to 4wheelparts.com and look under the ARB push bars
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
