charge and brake lights on - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 13 Old 04-08-2007, 02:46 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
About 6 months ago, I posted a question on this topic. I still have the problem and have been unable to track it down so I'm hoping there are some very smart toyota pickup people out there that can help me.
Around one year ago, my brake and charge light remained illuminated after starting the truck. Most toyota techs say this is an indication that their is a problem with the alternator. But, I've had the alternator checked out at Schucks and they could not find any problems with it. Also, I've now been driving the truck for a year with this situation so if there were a serious problem with the alternator I surely would have found out by now.
I've taken out all the dash and traced wires looking for any shorts to no avail. Also, i've checked out all the fuses and these too are good.
So anyone have any good ideas of how to fix this problem?
lakuen is offline
post #2 of 13 Old 04-08-2007, 03:15 PM
oh-pin-yun-A-ted
jakejjs's Avatar
Quoted: 0 Post(s)
maybe its that little wire from the battery to the fuse box
Originally Posted by qsd-dan View Post
Personally, I can't think of a better way to die than having a 22re in my lap.
1987 4runner, 22RE
jakejjs is offline
post #3 of 13 Old 04-08-2007, 04:54 PM
wheelinchick90's Avatar
Quoted: 0 Post(s)
my brake light also stays on after i drive for the truck for a while. it will eventually go away, but it will come back. Why?
wheelinchick90 is offline
post #4 of 13 Old 04-08-2007, 04:57 PM
A legend in his own mind.
Jakey_Jake's Avatar
Quoted: 0 Post(s)
when my truck is really cold and it doesnt warm up all the way sometimes my brake light comes on for a couple minutes, sometimes it turns on and off but when its warm and durning the warmer months it doesnt do it, toyotas are weird.
'93 4x4, 22re, std cab DLX....Gone
2003 Corolla S.....Sexy new
03 Corolla = Totaled
2003 Tacoma ext cab V6 SR5 even better
Jakey_Jake is offline
post #5 of 13 Old 04-08-2007, 04:58 PM
Quoted: 0 Post(s)
hmm, that what mine usually does. wierd. any way to fix it maybe. its kind of distracting...
post #6 of 13 Old 04-08-2007, 05:01 PM
Quoted: 0 Post(s)
Well, first thing would be to check the brake fluid level.
Then make sure up under the dash that the parking brake lever is pushing that little plunger to turn off that portion of the light.
Then ya needsta check that no hillbilly has been wiring on the tail lights for a trailer hookup or something to that effect.....you'd be amazed at how many problems I've seen as a direct result of people "scotch locking" wires together at the tail lights.
Bad diodes in an alternator can make the charge light come on even if it's charging fine.
Schucks won't have anyone smart enough to know how to test them.
Then check ALL fuses with a TESTLIGHT.
There is no other way to correctly test fuses.....and a testlight is less than 5$ at Ratty O' Shack.
ProBuilder is offline
post #7 of 13 Old 04-08-2007, 05:01 PM
Jakey_Jake's Avatar
Quoted: 0 Post(s)
ya i always freak at firts and see if ive been driving the last 5 miles with my brake on
post #8 of 13 Old 04-08-2007, 05:03 PM
Quoted: 0 Post(s)
oh yeah i way freak out too
it looks like im having a seizure...lol
post #9 of 13 Old 04-08-2007, 05:56 PM
Senior TN Member
Quoted: 12 Post(s)
Replace the $5 carbon brushes read below:
If the brake and charge lights come on during revving of the engine then it's a sign that the carbon alternator brushes require replacing as this is the mileage for them to wear out. In alternators the brushes wear out on average every 140-170 000 miles where on the dashboard the brake & charge light both come on at the same time. About half of the auto electric shops in your local yellow pages sell carbon alternator brushes and copper solenoid starter contacts for about $5/pair.
Another way to verify that the alternator is not charging is while the engine is running bring a metal screwdriver or any metal object near the alternator and if the alternator is working properly then it should act like a magnet and grab the screwdriver.
For carbon brushes R&R:
http://www.4x4wire.com/toyota/mainte...rnator_brushes
http://www.toyotaoffroad.net/afertig...torbrushes.htm
http://perso.wanadoo.fr/adherence.4x...nateur_kzj.htm
http://www.automotiveforums.com/vbul...d.php?t=166525
Rebuild your own alternator
http://www.pirate4x4.com/forum/showt...r+brush+holder
http://www.bitwalla.com/cruisers/art...lternator.html
http://www.barneymc.com/toy_root/tec...c/altrnatr.htm
For decoding the dashboard lights:
http://www.powerbase-auto.co.uk/alternator_faults.htm
http://members.1stconnect.com/anozir...alternator.htm
Here are part #'s for Toyota alternator carbon brushes and copper solenoid starter contacts which are used in about 95% of all Toyota vehicles.
Toyota alternator Brushes with holder:
Toyota # 27370-35060=$29 CDN
Honda # 31105-PZ1-003
Metro # 39-82003 (www.metroautoinc.com ,Pomona,California)
Unknown brand name # F4019-53035
Alternator brush only (qty:1 brush unless otherwise stated):
AC Delco # E724
AC Delco # E731 (side wire and concave tip)
Ace Electric # DA-61 (brush only),S-5367 (brush holder)
Beck Arnley # 178-1669 (side wire and concave tip)
Beck Arnley # 178-1376
Borg Warner # X580 (side wire and concave tip)
Canadian Tire # 19-2050-6=$4.49/pair
Daihatsu # 27370-87302-000
Daihatsu # 27371-63020-000
Daihatsu # 27371-87501-000
Daihatsu # 27371-70300-000
Echlin # E601=$8.16 CDN/pair (UAP/NAPA)
Echlin # ECHE601
Echlin # EC480
Echlin # ECHE480
GP Sorensen # 255047 (side wire and concave tip)
GM # 94123056
GM # 96054118
Honda # 31144-PD1-004=$9.72
Honda # 31144-PD1-0040
Honda # 31144-PD1-0030
Honda # 31150-PR7-A01
Honda # 31150-PTO-003
Hino Industries # 021660-0390
Hino Industries # 021660-0510
Isuzu # 8-94123-056-0
Isuzu # 8-97032-308-0
Isuzu # 8-97032-310-0
Mazda # 021660-0390
Mazda # 021660-0510
Mazda # KL47-18-W75
Metro # 38-82001(side wire concave tip) (www.metroautoinc.com ,Pomona,California)
Mileage Plus # E601SB
Mitsubishi # MD604474
Mitsubishi # 21660-0510
Niehoff # WA571 (side wire and concave tip)
NipponDenso # 021660-0390
NipponDenso # 021660-0510
Standard # JX-116 (side wire and concave tip)
Subaru # 021660-0390
Subaru # 021660-0510
Suzuki # 31631-82610
Suzuki # 31656-82611
Suzuki # 021660-0510
Toyota # 27370-42010
Toyota # 27370-75060
Toyota # 27371-63020=$5.80 (up to 9105) (side wire and concave tip)
Toyota # 27371-70300=$5.20 (9105-9511)
Toyota # 27371-76004-71
UAP/NAPA # MPEE601SB
Victory Lap # FAX57=$4.49 CDN/pair (Canadian Tire)
Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each CDN (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40 CDN)
Specifications:
Length=15 mm
Width=7 mm
Thickness=5 mm
Lead length=49 mm
These Honda alternators are the same except the pulley must be swapped:
1986-89 Honda Accord (Carb),the EFI can be used but the voltage reg must be swapped
1990-93 Acura Integra
For alternator upgrade:
http://www.off-road.com/toyota/tech/100alt/index.html
http://www.4x4wire.com/toyota/tech/alternator
http://home.earthlink.net/~twopapa/bigalt.htm
http://www.toyotaoffroad.com/Article.../Chevy_Alt.htm
http://www.alternatorparts.com/Toyot...lternators.htm
20 Toyota (NipponDenso now called Denso) starter repair sites:
http://www.off-road.com/4x4web/toyota/tech/starter/ -
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
http://char.tuiasi.ro/vw/reality/rog...s/Starter.html
http://yotarepair.com/startercontacts.html
http://www.toyotaoffroad.net/afertig...rterrepair.htm
http://www.4x4wire.com/toyota/maintenance/starter
http://www.yotatech.com/~corey/tech/...r/haveblue.htm
http://www.sleeoffroad.com/technical...er_rebuild.htm
http://www.startercontacts.com/install.htm
http://www.startercontacts.com/image...loded_view.jpg
http://www.colorado4x4.net/tech/star..._contacts.html
http://www.barneymc.com/toy_root/techneek/starter.htm
http://perso.wanadoo.fr/adherence.4x4/start_bj.htm
http://www.automotiveforums.com/vbul...d.php?t=166530
Repair your own STARTER
http://www.toyotanation.com/showthre...312&forumid=10
http://www.toyotaoffroad.com/Article...er/starter.htm
http://www.tacomaterritory.com/boophoenix/starter.html
http://www.tacomaterritory.com/booph...er/image01.jpg
http://www.team-integra.net/sections...ArticleID=1079
Starter contact kits (8mm ID hole):
Ace Electric # S-5263 (only two contacts)
Ace Electric # S-5264 (only two contacts)
Metro # 66-82104 (only two contacts) (www.metroautoinc.com ,Pomona,California)
Toyota # 28226-72010/80 (battery side)(also1KZTE-2LT-1KZT)
Toyota # 28226-72080 (8808-9108)
Toyota # 28226-16130 (9108-9308)
Toyota # 28226-55050 (9308-9511)
Toyota # 28226-70040 (9308-9511)
Toyota # 28226-72040 (motor side if needed)
Toyota # 28226-72010 (8808-9511)
Toyota # 28226-74070 (9108-9511) (2000 Tundra & others)
Toyota # 28226-22050 (2000 Tundra & others)
Toyota # 28226-66060 (1993-1997 Land Cruiser 2.0 KW starters)
For others besides 22R series:
Toyota # 28226-54220 (motor side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130,LN108,112,85..4FC)
Toyota # 28226-54250 (Diesel Surf 2.4TD, contains a new end cover and gasket)
Toyota # 28226-54320 (battery side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC,3B-1HZ-BJ73-HZJ7#-1KZT-KZJ70)
Toyota # 28226-17030 (battery side) (1H#-HDJ80-HZJ80)
Toyota # 28226-56250 (battery side) (3B-1HZ-1PZ-PZJ7#)
Starter contacts only (8mm ID hole):
Ace Electric # S-5231
Ace Electric # S-5293 (crescent moon shape)
Ace Electric # S-5295 (crescent moon shape)
Metro # 66-82106 (www.metroautoinc.com ,Pomona,California)
Tons more at:
http://www.metroautoinc.com/PDF%20Fi...%20Contact.pdf
Wilson’s Electric # 45-29-652 (maybe it’s 45-29-6521)
Starter brushes:
AC Delco # D762
GP Sorensen # 255048
Standard # JX-117
Whether your starter uses two rectangular types or one rectangular and one crescent you can substitute with two squares or one square and one crescent so any of the above part #'s for those kits will be the right ones,or about half of the auto electric shops in your local yellow pages would sell aftermarket contacts for only $5 each or the pair.
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,with 253 000 KM
for I am
Sidney is offline
post #10 of 13 Old 04-08-2007, 06:06 PM
yota bomber
93 toyota's Avatar
Quoted: 0 Post(s)
uhhh and if what syd dosen't work, i think i might know what it could be. if you have a trailer brake light system , you might have gotten water into the circuitry and blew a fuse or something along those lines. i know that happened to my friend in his ford and i don't see why it couldn't apply to our yota bombers....
keep us posted on your findings
-drew
93 toyota is offline
post #11 of 13 Old 04-08-2007, 06:36 PM
csxmoose's Avatar
Quoted: 0 Post(s)
my brake light has been on for about a year and a half now, mainly because i pulled my ebrake and snapped the cable, not sure if this has anything to do with your problem.
good thing i can just hand over $50 bucks to my buddy and he slaps an inspection sticker on my pos no questions asked
1991 Toyota Pickup 22re 4x4 3" body 5" susp 35x12.50's 150watt KC's 2.5" pacesetter, rancho steer/stab.
2003 Hummer H2 Vortec 6000 6.0, Air Susp Fully Loaded Pimper
csxmoose is offline
post #12 of 13 Old 04-09-2007, 01:59 AM
Senior TN Member
shoes1382006's Avatar
Quoted: 1 Post(s)
o check the connection between the alternator in the back! cuz that happened to me and the wire was being melted off so i recrimped with a new wire and it went away! and everything work great after that!
89' Yota 2WD 3VZ-TTE With Flows, Intake, Underglow, Black Paint Job, Black rims, Dual Stereo Deck n Lotz More By Clicking here... http://www.cardomain.com/ride/437849/
http://Projektnorkal.freeforums.org
shoes1382006 is offline
post #13 of 13 Old 04-09-2007, 10:05 PM
Quoted: 0 Post(s)
But why does mine ALSO kill the battery? I put a trickel charger on my 93 to keep it topped off. BTW the lights go out if I accelerate. Everything seems to work faster when the 2 lights come on.
sun622 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
