getting parking brake cable off handle. - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 7 Old 04-10-2007, 05:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I am trying to replace my front parking brake cable for 94 2wd p/u. I took off the switch for parking brake indicator light, and even took off the pulley, but fore the life of me, I can't get cable off the T-handle. Handle is pushed all the way forward, and I stll cna't see the cable end to get it out of the handle. Is there any trick? Thanks.
Dave
dave42 is offline
post #2 of 7 Old 04-10-2007, 05:41 PM
csxmoose's Avatar
Quoted: 0 Post(s)
i have to replace mine also, how much did your cable cost?
sorry i couldn't help
1991 Toyota Pickup 22re 4x4 3" body 5" susp 35x12.50's 150watt KC's 2.5" pacesetter, rancho steer/stab.
2003 Hummer H2 Vortec 6000 6.0, Air Susp Fully Loaded Pimper
csxmoose is offline
post #3 of 7 Old 04-10-2007, 05:51 PM
Offical Truck Nut
1bad2WD's Avatar
Quoted: 0 Post(s)
you have to take it all out handle and all
2002 Tundra V-8, cab TRD, limited 130,000
2002 Tacoma Regular cab 52,000
1bad2WD is offline
post #4 of 7 Old 04-10-2007, 06:09 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I paid about $50 including shipping from www.1sttoyotaparts.com . But how do i take the handle out? Right now I have the pulley out, but the handle only pulls out so far and stops.
dave42 is offline
post #5 of 7 Old 04-10-2007, 06:18 PM
Quoted: 0 Post(s)
you have to press the two silver things at the end of the bracket on the handle side. pull them back, then puck the handle froward
92 xtra cab dlx 4x4 22re, LC headers, 2 1/4 exhuast w/ resonator, 4.88s, 33x12.50x15 trxus M/T, trailmaster lift, procomp shocks steering stabilizer ss brake lines, new calipers, 4runner power interior, rhino lined, dynamat interior
cbm! is offline
post #6 of 7 Old 04-10-2007, 06:40 PM
Offical Truck Nut
1bad2WD's Avatar
Quoted: 0 Post(s)
I tried that ,got mad, took the whole thing out and did it on the table
1bad2WD is offline
post #7 of 7 Old 04-12-2007, 10:00 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
For anyone who needs to do this procedure, I ended up removing the 2 bolts above the handle that secure the assembly to the underside of the dash near the ignition switch. I was then able to lower the assembly down enough so I could see the hole in the handle where the cable needed to slip in. This involved twisting the handle extremely clockwise to the point where I thought it would break....but it worked.
Dave
dave42 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
