NO POWER to anything - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 15 Old 07-06-2007, 07:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 94 pickup 22re 4 cyl. I have no power to anything. No its not the battery. I has almost 13 volts. The truck wont start. It wont turn on any accs. lights, radio, nothing. I checked all the fuses and they all are good. Any sugestions of what could be wrong. Please help.
Thanks
MIKE Z is offline
post #2 of 15 Old 07-06-2007, 07:06 PM
Quoted: 2 Post(s)
Did you check the large amp fusible link between the battery cable and the cars electrical system?
Also check the battery cables, both ends.
toyomoho is offline
post #3 of 15 Old 07-06-2007, 07:13 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Cables are good. There is power to the main fuse block thats above the battery. I checked the am1 and am2 fuse location and the both have plenty of voltage along with the alt 80amp fuse. Still nothing
MIKE Z is offline
post #4 of 15 Old 07-06-2007, 11:08 PM
yota bomber
93 toyota's Avatar
Quoted: 0 Post(s)
check the lineouts on the fuse box, some fuse box diagrams arn't always 100% true...
93 toyota is offline
post #5 of 15 Old 07-07-2007, 03:05 AM
Not a Pre-runner
Twisted Sid's Avatar
Quoted: 73 Post(s)
my sister has a 99 4runner and this same thing happened. she was driving down a road and she lost all power and nothing worked. no lights no acc. no nothing. no fuses were blown under the dash or under the hood and nothing looked out of the ordinary. it ended up being her starter shorted out and grounded itself through the chassis and it was drawing all the power from the battery. mechanic said it damn near burned a hole in the side of the starter because it got so hot.
94 Pickup:22RE, 5spd, 2wd
Total Chaos Uniball Kit, Fox 8''Coilovers, Deavers, Fox 14'' 2.0s, E-locker Axle 33x10.5 BFGs
99 4Runner: V6 Daily Driver
Twisted Sid is offline
post #6 of 15 Old 07-07-2007, 03:59 AM
Senior TN Member
shoes1382006's Avatar
Quoted: 1 Post(s)
Terminals
89' Yota 2WD 3VZ-TTE With Flows, Intake, Underglow, Black Paint Job, Black rims, Dual Stereo Deck n Lotz More By Clicking here... http://www.cardomain.com/ride/437849/
http://Projektnorkal.freeforums.org
shoes1382006 is offline
post #7 of 15 Old 07-07-2007, 08:09 AM
yota bomber
93 toyota's Avatar
Quoted: 0 Post(s)
it shouldn't be the terminals if hes getting power to the fuse box though
post #8 of 15 Old 07-07-2007, 08:44 AM
Quoted: 0 Post(s)
Bad ground??? do you have a security system that might disable some of the electrical system? have you tried bypassing the selonoid/switch circut with a jumper cable from the batt to the starter? how did the problem happen? was it sitting in the driveway, driving down the highway or bounceing down a trail?
Thanks,
88 P/U 4x4 22re K&N filter high flow muffler. Soon: custom flat deck, head/cam work, supra bucket seats
94 4runner. 5sp 22re. Assin manual hubs. Soon: sound system
22re for life is offline
post #9 of 15 Old 07-07-2007, 07:43 PM
Senior TN Member
Quoted: 14 Post(s)
The 22-RE is used in many years of 4-Runners/pickups therefore the free 1985 Toyota 4-Runner/pickup factory service manual below has electrical diagram pages that allow you to isolate fault.Be sure to check main relay above fuses in driver's side kick panel.
In North America the 22R & 22R-E s are used in the following:
22R
1981-82 Toyota Corona
1981-83 Celica
1981-87 Toyota pickup (up to 1990 on 2wd)
1984-87 Toyota 4-Runner
22R-E (22REC=California emissions=extra charcoal canister)
1983-85 Celica
1985-95 Toyota pickup
1985-95 Toyota 4-Runner
22RTE (Turbo EFI)
1985-87 Toyota 4-Runner
1985-87 Toyota pickup
Free 1985 Toyota 4-Runner & pickup Factory Service Manual:
http://www.truckporn.com/tech/FSM/Toyota/1985fsm.zip
http://s3.uploadline.com/d/4831811/1...85/1985fsm.zip
http://www.subliminaltrips.com/1985toyotatruckfsm.pdf
you may also need to install this:
http://www.subliminaltrips.com/AmazingDown.exe
heres the instructions
1985 FSM - READ FIRST
This FSM works for the stock solid front axle trucks
And for more free service manuals:
Any Public Library in your area would have the Factory service manual, Haynes,Chiltons,Mitchells,Clymers, Bentley and Toyota repair books.
Free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiB...pair_guide.jsp
Tons of free factory service manuals for 4-Runners,etc:
http://forum.ih8mud.com/showthread.php?t=128021
NOTES:
If you have a pre-84 vehicle with an external voltage regulator, the ignition/charging section will not work for you. If you have an ’85 vehicle, make note as to whether you are carbed or EFI, as the ignition systems are not the same.
Accurate links for pre-84 charging/ignition systems would be appreciated.
Regarding the FSM, WARNING: Do not try and open this file over the internet no matter HOW fast your connection is; Adobe WILL lock up. This document is 1025 pages long!
Tech note from lscotte: Firefox users may not need this download tool. Right click>save link as...
Download AmazingDown 1.62 first.
Then in that program press the "New" button on the tool bar and copy and paste the URL below into the corresponding dialogue box and click download. This will greatly speed up the process of downloading such a big file from a server that isn't quite the fastest out there. Once the file is downloaded you can open it from your hard drive. (folder entitled ‘downloaded’)
Free 1993 Toyota Pickup Service Manual:
http://personal.utulsa.edu/~nathan-buchanan/93fsm
Free 1989 - 1995 Pickup Mitchell Service Manual:
You can download the winrar archiver from: http://www.rarlab.com/download.htm
And The ISO file can be downloaded from:
http://www.filecrunch.com/file/~ga05yg <--- Part 1
http://www.filecrunch.com/file/~tlgobs <--- Part deux
The two rar files are 90 Megabytes in size, but once unrared it is a 300 Megabyte ISO image.BTW: File will be removed automatically if there is no download for 30 days.
FSM (factory service manual) can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton, CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers, websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
Sidney
Repairs TV's,VCR's,home/car audio out of my apartment
E-mail:sidneybek(at)yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 255 000 KM
for I am
Sidney is offline
post #10 of 15 Old 07-07-2007, 09:33 PM
Quoted: 0 Post(s)
I had this same issue. The ground terminal at the battery was bad.
92trk is offline
post #11 of 15 Old 01-15-2016, 10:02 AM
Quoted: 0 Post(s)
I have a 1994 yota 2wd 4clyde Manuel transmission I ground out the battery I check all fuses inside and out and u have power to them but I still have no power to the truck no lights turn on or nothing no radio headlights etc. What can it be any help would work thanks
94 yota man is offline
post #12 of 15 Old 01-16-2016, 03:48 PM
Quoted: 0 Post(s)
im having the same problem and I cant find out what the problem is I have power to both fuse boxes
post #13 of 15 Old 01-16-2016, 09:27 PM
Quoted: 13 Post(s)
Inspect the positive battery cable and terminal at the starter solenoid. If there is a second cable, possibly a 12 awg cable, connected at the same terminal, it could be that this cable is damaged (open).
roadsterred is offline
post #14 of 15 Old 01-16-2016, 09:45 PM
ajay842's Avatar
Quoted: 160 Post(s)
This isn't my normal neck of the woods, but is the ignition switch known for problems? Could be that based off of what you're describing.
ajay842 is offline
post #15 of 15 Old 03-07-2017, 05:49 PM
Quoted: 0 Post(s)
I have a 94 Toyota Pickup 4 wheel drive four cylinder replace the starter battery. I drove 10 miles turned it off want to restart no lights no power no nothing any suggestions?
Sara Berghuis is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
