Instrument cluster removal - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 6 Old 09-13-2007, 04:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Does anybody have the directions to remove an instrument cluster on a 89 Toyota PU SR5 4x4. I need to replace the speedometer cable and hate ripping plastic tabs off.
funky is offline
post #2 of 6 Old 09-13-2007, 05:40 PM
7MGTE/22RE
shaeff's Avatar
Quoted: 0 Post(s)
do '89's have a speedo cable? my '94 has a speed sensor, not a cable.
might want to double check that.
but to answer your question about dash removal, you need to start from the glove box and work your way to the left.
-shaeff
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline
post #3 of 6 Old 09-13-2007, 05:42 PM
Quoted: 0 Post(s)
Yes they have a cable, my 91 has a cable
91 Ext cab delux 4x4 pushing 227k
zyphera is offline
post #4 of 6 Old 09-13-2007, 06:46 PM
Senior TN Member
Quoted: 19 Post(s)
-shaeff
I've replaced my cluster and didn't have to remove any of the passenger side dash. I did have to remove from the bottom up on the drivers side, so start with the lower pieces and also the bezels that go around the radio and hvac controls and work your way up. Once all that's removed, you can then unscrew out the cluster and hopefully gain access to the back to unhook the cable. My suggestion, if something seems blocked by another item, don't try to force it, just remove the other item, it'll be worth it later when you dont have broken pieces.
BTW there was a change over year from which they moved from cable driven to electronic. I think its around 92. So most likely you do have a speedo cable.
SuperRA is offline
post #5 of 6 Old 09-13-2007, 08:43 PM
Supafly
Jayota's Avatar
Quoted: 0 Post(s)
whatever you do, start early and give yourself LOTS of time This stuff is not hard, just time consuming.
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline
post #6 of 6 Old 09-14-2007, 06:24 PM
7MGTE/22RE
shaeff's Avatar
Quoted: 0 Post(s)
they changed the dash design somewhere between '91 and '94, as mine is different from my friend's '91.
if you click the link in my sig, you can see some step by step pics. (just stop before you get to the heater core. haha
-shaeff
shaeff is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
