Vacuum Hoses Diagram and VSV ??? - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 10 Old 12-02-2007, 07:38 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Does any one know where I can find a vacuum hose diagram for a 91 Toyota Truck (4x4) 3.0?
I think I have a few hoses misconnected cause I am getting a 71 code (EGR)
My EGR valve is fine so is the vacuum modulator and coolant temp sensor.
I am not getting any vacuum to the EGR (cold or hot) so I need to trace back to the source of the vacuum. I thin it could be a faulty VSV or a hose misplaced in the wrong location. More so a misplaced vacuum line since my motor was taken out recently and the mechanic said he is not sure he placed back the vacuum hoses to the original place he removed them from.
By the way, out of the 4 valves that look like a VSV, which one is the VSV for the EGR? The color of the electrical harnesses are Blue, Red, Green, and Silver in that order from left to right (as looking on the passenger side).
Thanks
ToyoZone is offline
post #2 of 10 Old 12-02-2007, 08:26 PM
Quoted: 0 Post(s)
I think the factory service manual is on the sticky. It is a bit hard to follow, there also may be some pictures posted by others who have had the same problem. Good luck with this tedious project.
Georgiadave is offline
post #3 of 10 Old 12-02-2007, 09:02 PM
Former Toyota/ASE Master
Qslim's Avatar
Quoted: 1 Post(s)
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline
post #4 of 10 Old 12-02-2007, 10:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Diagram
Thanks for the diagram. It helps a lot.
I discover the metal vacuum line is plugged. I guees it got some humidity and got corroded inside. It's clean now but I think I will check all other vacuum lines now that I am on it.
Thanks again.
ToyoZone is offline
post #5 of 10 Old 02-11-2008, 03:06 PM
Quoted: 0 Post(s)
Sorry bout the hijack, but what is the real / full name for a VSV?
aych is offline
post #6 of 10 Old 02-11-2008, 03:12 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I think it stands for Vacuum Solenoid Valve.
ToyoZone is offline
post #7 of 10 Old 02-11-2008, 10:59 PM
Qslim's Avatar
Quoted: 1 Post(s)
Vacuum switching valve. It switches vacuum on and off.
-- Get him, boy....
Qslim is offline
post #8 of 10 Old 02-13-2008, 04:13 PM
7MGTE/22RE
shaeff's Avatar
Quoted: 0 Post(s)
^ you don't happen to have a diagram like that for the 22re, do you?
My heater core replacement writeup with pics: http://www.toyotanation.com/forum/t209136.html
1994 Toyota 4x4, 31x10.50, 22re. <- to undergo high compression 7MGTE swap whenever i finish building it.
1986.5 Toyota Supra- 300+rwhp. (capable of over 400, but i haven't tuned it yet)
shaeff is offline
post #9 of 10 Old 02-13-2008, 08:16 PM
Quoted: 0 Post(s)
if you can tell me the generation, i might be able to find it.
aych is offline
post #10 of 10 Old 02-13-2008, 11:15 PM
Qslim's Avatar
Quoted: 1 Post(s)
Ask and ye will get it. This excludes cali emissions models.
-- Get him, boy....
Qslim is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
