code 14 - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 8 Old 01-29-2008, 10:58 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
code 14
I have a 93 v6 pickup and the check engine light just came on. I did the trouble code diagnostic,
code 14 which is no "IG" or "IGF" Ignition To ECM from Ignitor several times in succession.
does any one know what that means..
93yotaman88 is offline
post #2 of 8 Old 01-29-2008, 11:03 PM
toytruck89's Avatar
Quoted: 0 Post(s)
means the ECM isn't getting anything from the igniter.. wouldn't be the first v6 igniter I have seen go bad.. try one from a buddy's truck that has matching numbers and see if it starts. cheap way to diagnose it quickly
89 toyota 22r - my baby, the popo's have her now
86.5 supra - waiting for shop space to 2jz swap
91 4Runner - 3.4 swapped automatic, BJ spacers, lift springs
67 C10 - LS1 twin turbo swapped
toytruck89 is offline
post #3 of 8 Old 01-29-2008, 11:03 PM
toytruck89's Avatar
Quoted: 0 Post(s)
means the ECM isn't getting any signal from the igniter.. wouldn't be the first v6 igniter I have seen go bad.. try one from a buddy's truck that has matching numbers and see if it starts. cheap way to diagnose it quickly
post #4 of 8 Old 01-29-2008, 11:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
It still runs. but should i still need to get another one.
post #5 of 8 Old 01-29-2008, 11:48 PM
toytruck89's Avatar
Quoted: 0 Post(s)
never seen that before.. let me look up the code to get a better idea.. 93 toyota 4wd v6?
post #6 of 8 Old 01-29-2008, 11:57 PM
toytruck89's Avatar
Quoted: 0 Post(s)
it appears your igniter or ignition coil is going out. Most of the time it just dies. but here is the DTC sheet for it.. it tells you where to look to solve the problem, but this one is pretty basic. I wouldn't really worry about it unless it stops running, which I suspect it will. Is it misfiring?
post #7 of 8 Old 01-30-2008, 09:47 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Not really it runs good. every once and a while it will miss. how bad is the igniter to change .
post #8 of 8 Old 02-01-2008, 04:51 PM
Senior TN Member
Quoted: 12 Post(s)
Did you check your spark plugs if bad use genuine Denso or NGK also available aftermarket.
About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered.
To pull the ECU codes:
All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner, the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it:
http://autorepair.about.com/library/...bl-dtcs-36.htm
http://autorepair.about.com/library/...bl-dtcs-53.htm
http://autorepair.about.com/library/...bl-dtcs-71.htm
http://autorepair.about.com/library/...bl-dtcs-90.htm
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
http://www.off-road.com/toyota/tech/codes/index.html
http://www.4crawler.com/4x4/CheapTri...CheckConnector
http://www.4crawler.com/4x4/CheapTri...osticcodes.gif
http://lcengineering.com/TechNotes/TechNote12.htm
http://lcengineering.com/TechNotes/TechNote13.htm
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.mad-mechanic.com/toyota/t...tml#obtaincode
http://www.freewebs.com/th3duke/22RE-ECU.mht
http://www.troublecodes.net/Toyota
http://www.autoshop101.com/forms/h27.pdf
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
http://www.showmesome.info/hilux/inf...E/Page0096.htm
http://www.efisakh.narod.ru/at_toyota.htm (auto tranny codes)
http://www.usatransdoctor.com/foreigntoyota.htm
http://www.obd-codes.com/forums/viewforum.php?f=3
Pulling the ECU (EFI computer) codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements at each ECU wire both with the engine running and not and compare with the factory service manual, I also close the ignition switch after a cold engine and also after a warm engine and compare the resistance values with the factory service manual. This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's, vcr's, home/car audio.
Sidney® ™
Repairs TV's,VCR's,home/car audio out of my apartment
E-mail:sidneybek(at)yahoo.com
Dartmouth,Nova Scotia
Canada
Sidney is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
