1990 pickup starter motor problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 10-23-2003, 04:38 PM   #1 (permalink)
View hopalong's Photo Gallery
i finally got the truck of my dreams!
we were running great for the first month, and now have run into a small problem.
starting the truck is inconsistent,
turning the key sometimes produces no results, the engine doesnt even turn over, but i do hear the 'click'.
battery seems fine, as my stereo still runs and all the lights power up (and battery indicator shows ample)..
sometimes with multiple tries (stressing the multiple), i'll be able to get it started, if not, it has to be a rolling start & popping the clutch.
any suggestions?
hopalong is offline   Reply With Quote
Old 10-23-2003, 07:24 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
the contacts in the soleniod are worn out, look in your phone book for an alternator rebuilder in your area and take it there. Tell them you ONLY want the contacts replaced. Shouldn't cost more than $20.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 10-26-2003, 02:19 PM   #3 (permalink)
View riverview's Photo Gallery
Before you put any money, get some jumper cables. Jump the neg at the batt to starter ground. And see if she starts. If so remove starter and clean mounting area and bolts and re-install. Or make a new jumper ground?
riverview is offline   Reply With Quote
Old 10-28-2003, 07:47 PM   #4 (permalink)
View Edgeman's Photo Gallery
If you have a 22R/22RE...
then change that fuel filter while you have the starter off. I had to pull the starter just to reach the fuel filter.
That was the one that that left me scratching my head on why the Toyota engineers put it there. For such a simple thing, it was a bee-otch to reach.
Edgeman is offline   Reply With Quote
Old 04-09-2007, 10:31 PM   #5 (permalink)
csxmoose's Avatar
View csxmoose's Photo Gallery
XXX
two words... star der
1991 Toyota Pickup 22re 4x4 3" body 5" susp 35x12.50's 150watt KC's 2.5" pacesetter, rancho steer/stab.
2003 Hummer H2 Vortec 6000 6.0, Air Susp Fully Loaded Pimper
csxmoose is offline   Reply With Quote
Old 04-09-2007, 11:24 PM   #6 (permalink)
View instantninja's Photo Gallery
you don't even need to replace the contacts if they were like mine, I tore the starter apart, cleaned up all the contacts with a dremel and put it back together, didn't cost me a thing, other than a couple hours of my own time.
1992 Toyota Pickup, 2wd 22re
enginbuldr rv cam, timing chain kit and street head
1992 toyota hilux surf, 4wd, 2.4 turbo diesel, rhd
instantninja is offline   Reply With Quote
Old 04-10-2007, 01:06 AM   #7 (permalink)
wheelinchick90's Avatar
View wheelinchick90's Photo Gallery
hey hopalong*
i have the same problem
sometimes my truck wont start
it wont even turn over
maybe our trucks are related
mines a 90 also
wheelinchick90 is offline   Reply With Quote
Old 04-10-2007, 07:22 AM   #8 (permalink)
Languishing in Maryland
TNRabbit's Avatar
Gameroom cash: $146760
View TNRabbit's Photo Gallery
The VERY FIRST thing you need to check is both posts on the battery; remove them completely & clean them up with sandpaper. Make sure you remove ANY corrosion from the contact points. If that doesn't solve your problem, get your battery tested. After that, I would check starter contacts at the starter. Next, replace the starter contacts. Do it in that order to minimize your costs & headaches! That's the order I've found these problems to be in, plus you're not removing the dang PITA starter before you rule out other problems.
TNRabbit
STOCK '94 DLX XtraCab 4x4, 5 spd, 3VZE, 267,000 mi.
AISIN Manual Hub Swap, Rebuilt Engine & New Clutch, Flywheel, Front Wheel Bearings/Seals, & Stock Exhaust
TNRabbit is offline   Reply With Quote
Old 04-10-2007, 04:03 PM   #9 (permalink)
View JSTMoto's Photo Gallery
i agree with everyone else, its the start solenoid contacts. They are only like 5-10 bucks and you can do it yourself.
Go here:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
or here:
http://www.4x4wire.com/toyota/maintenance/starter/
both have great info to replace the contacts
-ja
94 Toyota P/U XtraCab 4x4 - 3vz-e 3.0L v6, 5-speed - Pioneer 600W Amp, 6.5" 220W pioneer speakers in back, 110W 4" speakers in front - Keyless Entry (just got kit,installing soon)
http://www.cardomain.com/ride/2398844
JSTMoto is offline   Reply With Quote
Old 04-10-2007, 04:53 PM   #10 (permalink)
0 to 60 in 2.4 miles
View ScoobyRoo's Photo Gallery
I really hope after 4 years this guy managed to figure that one out...
ScoobyRoo is offline   Reply With Quote
Old 04-10-2007, 05:05 PM   #11 (permalink)
TNRabbit's Avatar
Duh...good call....I have to start looking at the dang post dates!
TNRabbit
Old 04-10-2007, 05:07 PM   #12 (permalink)
csxmoose's Avatar
ahahahaha, i figured i'd be a smartassby hittin up the last post possible
just see'in who's payin attention
