Manual Transmission Noise - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 7 Old 03-15-2008, 07:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hey All,
I just picked up a 1991 2wd truck with 124k on the clock (I suspect that it has more on it though), a 22-RE engine and a 5 speed manual transmission. It is a basic model with no power steering, or power anything for that matter!
When i bought it, it had a bad fan belt squeal and barely made it home. I went ahead and went whole hog, replacing the radiator (had a small leak), water pump, fan clutch, thermostat, hoses, and fan belt and now she's doing much better.
Problem is that after the fan belt noise was taken care of, I noticed a bit of noise coming from the transmission. It is a "rotating" noise that goes away when the clutch is pushed in. This happens if the truck is moving or at a standstill. In addition to this, it seems to make a bit of a whining noise in 1st- hard to tell though.
I checked the tranny oil and it was a little low (under a quart) so I topped it off. I would have replaced it, but don't have the correct socket for the drain plug.
What do you guys think? It pulls and shifts just fine through all gears, just makes a bit of noise. No "clunky" or "chunky" metal noises.
The clutch grabs close to the floor and supposedly was replaced not to long ago... the fact that it doesn't happen when the clutch is depressed makes me think that it is the tranny. I don't think that it could be anything from the transmission back b/c it makes the noise at a standstill.
I am all ears (eyes) if anyone has suggestions.
Thanks,
plan9
plan9 is offline
post #2 of 7 Old 03-16-2008, 12:32 AM
DCM
One with the farce
Quoted: 5 Post(s)
It sounds like your input shaft bearing is on its way out.
'92 ST185 All trac turbo
'91 Cressida
'72 TE27
DCM is offline
post #3 of 7 Old 03-16-2008, 06:02 AM
ohgood's Avatar
Quoted: 0 Post(s)
Originally Posted by plan9 View Post
Hey All,
Thanks,
plan9
(with this first bit I'm assuming allot, so if I'm wrong, ignore it ok ?)
hey, welcome to the forum sir/ma'am. your OS would have been so much nicer than win32, but sigh, here we are. i've only met 6 people that knew what plan9 was so far. i'm not a user, (mac os here) but it's concepts are awesome, and blah blah blah - so welcome anyway
before you get to far along into loving your 'new' truck, you'll want to make sure it's going to keep on going.... if you haven't checked out your timing chain yet, do so. quite a few owners just drive the truck until it destructs, and the PO may have not changed it yet. i'm assuming the 91 has a chain instead of a belt, but eiher way, it's likely due for service.
welcome again !
ohgood is offline
post #4 of 7 Old 03-16-2008, 09:40 AM
YOTA Master
Vicoor's Avatar
Quoted: 3 Post(s)
"A Bit" of trans noise is pretty normal from these transmissions.
Actually I was drove friend's 2001 4cylinder tacoma 2wd the other day and I think his trans is just as noisey as mine.
I'd get the gear oil changed and drive it and see how it progresses.
Make sure you get 75w90 so it won't be stiff to shift in the morning!
Don't talk about it, Just do it!
Vicoor is offline
post #5 of 7 Old 03-16-2008, 12:31 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
are all gear oils created equal
I figured it was a noise that I was going to have to live with. I don't mind pulling the transmission and replacing a bearing if I must, but would rather try the oil change per your suggestion first.
Is there a brand/type that would work better than others in this situation?
Thanks,
plan9
plan9 is offline
post #6 of 7 Old 03-16-2008, 01:25 PM
Quoted: 1 Post(s)
Not sure it would make one bit of difference but you could clean up the transmission with a product called Auto-Rx. http://www.auto-rx.com/auto-rxnet/index.html
V62WDLongbed is offline
post #7 of 7 Old 03-16-2008, 02:01 PM
Quoted: 0 Post(s)
Yes, Redline MT90.
qsd-dan is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
