temp sender - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 10 Old 04-21-2008, 08:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
temp sender
Can some please help me out? I have a 93 22re; A short while ago I had a problem with my temp guage going immeadiately to red after starting. Soon after it just stopped working. Today I changed my temp sender and noticed that its began doing the same thing. Also it would blow the EFI fuse everytime it went to red . I thought previously that there was a break in my o2 sensor line/harness as to why the EFI fuse would blow. But now it seems that its from the temp sender, what is the relationship of the temp sender and the EFI fuse? Please, I'm opened to all and and any suggestions.
caf325 is offline
post #2 of 10 Old 04-21-2008, 09:24 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
temp sender
Anyone???????????
caf325 is offline
post #3 of 10 Old 04-22-2008, 06:35 AM
Senior TN Member
Quoted: 12 Post(s)
Sidney is offline
post #4 of 10 Old 04-22-2008, 11:08 AM
Soylent Green sales
fourwd1's Avatar
Quoted: 250 Post(s)
Originally Posted by caf325 View Post
Anyone???????????
The temp gauge sending unit and the EFI ECM temp sensors are completely different, so there's really no connection between the two.
A bad temp gauge/sender should not affect the EFI fuse.
The power for the cluster guages is via the Engine fuse.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #5 of 10 Old 04-22-2008, 11:22 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I kinda felt that but I'm curious as to why the EFI all of sudden began blowing fuses again after I changed the temp sender and the guage began to function again. Could the temp sensor be the problem?
caf325 is offline
post #6 of 10 Old 04-22-2008, 09:04 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 250 Post(s)
I can't think why the EFI fuse would start blowing, but there's probably many possibilities.
89 4Runner - stock
fourwd1 is offline
post #7 of 10 Old 04-22-2008, 10:04 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
temp sender
Well here is an update, I unplugged the o2 sensor and plugged the temp sender and after about 5 minutes of idling the efi fuse blew. However when I unplugged the temp sender I was able to drive it several miles with no problem. I did notice that the temp sender wire had a bad spot along with copper showing right at the harness.
caf325 is offline
post #8 of 10 Old 04-24-2008, 04:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
temp sender
I found the problem!!!!!!!!!!!! It was the group of wires ( temp sender, cold start, fuel injectors wires) that rest as a bundle on top of the fuel rail. The underside of the bundle of wires had begun rubbing through the insulation. WHEW!!!!!!!!!!!!! Thanks to all that offered suggestions.
caf325 is offline
post #9 of 10 Old 04-24-2008, 09:55 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 250 Post(s)
Great, glad you found the problem.
89 4Runner - stock
fourwd1 is offline
post #10 of 10 Old 04-25-2008, 09:23 PM
Quoted: 0 Post(s)
caf325, Could you somehow post a picture of exactly where the wires are rubbing. That might be something other people would want check out to keep the same thing from happening to them. Just a thought :0 Rickisan
06 xB 16,003mi.
00 Ody 94,800 mi.
99 Saturn 118,000mi.
95 Celica 124,000mi.
89 HILUX 22R 219,452mi.
Rickisan is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
