Radio Antenna Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners.
post #1 of 6 Old 05-06-2008, 11:23 AM Thread Starter
flamesFan77's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hey all, has anyone ever replaced their radio antenna on a '90 ish pickup? My Haynes guide sucks ass and is very general.....seems to me that Chilton's puts out a more thorough book. Any advice on the steps to get the old one out and the new one in would help. The truck came with a replacement aerial, but no instructions of course.....
Cheers
flamesFan77 is offline
post #2 of 6 Old 05-06-2008, 05:40 PM
Quoted: 0 Post(s)
I have an 89 4wd and ended up taking that right front quarter panel pretty much off. It was a PITA, but not the worst thing I've ever done. The bolts aren't hard to find, just make sure the door doesn't scrape when you put it back together.
Hope this helps,
Steve
stevesemti is offline
post #3 of 6 Old 05-07-2008, 02:25 AM
Quoted: 0 Post(s)
if you are replacing the base and wire you will have to take out the inner fender and possibly the wheel to make it easy to reach. The correct and extremely easy way to remove the old antenna is with a antenna socket. I have seen them on all the major tool trucks but they might be kind of hard to find other places. A pair of pliers/vice grips/ body saw /whatever will get it off but with significantly more work. The factory antenna comes in a grommet behind the passenger kick panel and runs behind the glove box. The glove box will need to be removed and possibly the radio depending on how tight it is.
animatronic is offline
post #4 of 6 Old 05-07-2008, 11:26 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks very much for your help guys. So the base/wire is a one peice deal then? It'd be nice to be able to replace the base and antenna and not have to remove body panels.
Cheers
post #5 of 6 Old 05-07-2008, 12:48 PM
Dave's
Quoted: 26 Post(s)
If I remember correctly, on my '91 I turned the wheels hard right and removed the screws to the back part of the inner fender. Mine also has an extension between the antenna lead and the radio. The real problem was finding a replacement to fit the extreme angle of the fender.
Dave's is offline
post #6 of 6 Old 05-07-2008, 07:04 PM
greypickup94's Avatar
Quoted: 0 Post(s)
i replaced my whole antenna assembly not too long ago with an oem antenna i ordered from one of the online toyota sites. you have to remove the inner fender cover, its about 10 10mm screws, and the antenna has a tube that bolts onto a bracket to support it. mine had cracked there so it would no longer support the antenna. the wire is connected to the base so you have to take the dash apart and run the new antenna wire to the radio. i think i just cut the old wire off the base and used it to pull the new wire through the grommet. hope this helps.
sean
1994 Regular Cab Pickup, 22re, 5 speed, SAS, 4.88s, ARBs, 33s, and a sweet antenna spring
greypickup94 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
« Back
