Coolant Temperature sensor sending unit - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 08-15-2008, 06:48 PM   #1 (permalink)
View sevitzky's Photo Gallery
On a 1993 22RE, where is the coolant temperature sensor?? After reading Haynes, FSM, and online searches, I can't find it.
Keywords: CTS, ECT sensor, Coolant Temperature Sensor
EDIT:
After much soul searching, it appears that the Engine Coolant Temperature (ECT) Sensor is attached to the green connector below.
1993, 22re, 2wd, (w55)
152k mostly bone stock
Mods: Roof rack and basses in the back.
Last edited by sevitzky; 08-24-2008 at 06:02 AM. Reason: photo, remove agro comments
sevitzky is offline   Reply With Quote
The Following User Says Thank You to sevitzky For This Useful Post:
JatMat (07-15-2012)
Old 08-15-2008, 10:59 PM   #2 (permalink)
Saving lives
IronNam's Avatar
Gameroom cash: $630730
View IronNam's Photo Gallery
temp sensor on 90 22re?
1994-Toyota-Hilux-XCab-DLX-22RE-W58-8"V6
89-95 Hilux
89-95 Hilux FAQ
89-95 Hilux Massive Truck Info
IronNam is offline   Reply With Quote
Old 08-16-2008, 07:28 AM   #3 (permalink)
THANKS, DubVipers (I swear I did multiple searches)
Does anyone know how to test this according to the FSM, which specifies decreasing resistance as temperature increases? Specifically, how do you measure the temperature? (No #'s on my dash temp gauge) Or do you just start the vehicle and watch the resistance dec. as it warms up?
Sev.
Old 08-24-2008, 01:59 AM   #4 (permalink)
View thatsright72571's Photo Gallery
its the green one, take it out and stick it in cold water and measure with a volt meter on ohms setting., should read high ohms in cold and low ohms in hot water. low being 0.2 high being 1400. hope this helps.
thatsright72571 is offline   Reply With Quote
The Following User Says Thank You to thatsright72571 For This Useful Post:
JatMat (07-15-2012)
Old 08-24-2008, 06:07 AM   #5 (permalink)
Thanks, that helps.
It would be easier to take it out and test it, duh. I thought I had to test the unit by running the engine and measuring the heat in the radiator...
Old 07-15-2012, 10:36 AM   #6 (permalink)
View JatMat's Photo Gallery
I needed this BAD! Thank You.
JatMat is offline   Reply With Quote
Old 07-17-2012, 11:52 PM   #7 (permalink)
View pluton's Photo Gallery
Keep in mind that the discussed sensor is the one that reports to the computer, not the gauge.
'91 22RE 5spd reg cab 4WD. 250K+ miles. 31"/4.56 Budbuilt skid, and a really nice TJM front bumper. Currently not leaking anything.
pluton is offline   Reply With Quote
The Following User Says Thank You to pluton For This Useful Post:
JatMat (07-18-2012)
