Washer Fluid Pump - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-08-2008, 02:05 AM   #1 (permalink)
TN Member
trivletrav's Avatar
View trivletrav's Photo Gallery
Washer Fluid Pump
Hi there,
so I dont' know what exactly caused it, but i've noticed that whenever the washer fluid level goes down past 2/3 full, it doesn't pump any fluid out of the jets...but when it's full, it pumps normally...
i'm wondering where the pump is in the engine (22re) and how hard it is to replace...
thanks in advance!
-travis
1994 4Runner 4WD 5spd SR5 Base 22RE Blue-- Completely rebuilt at 154,837.
1994 22RE 4WD 5Spd Regular Cab DX. White ZEV 1- SOLD
1994 22RE 2WD 5Spd Regular Cab Base Red-Now dad's car
trivletrav is offline   Reply With Quote
Old 09-08-2008, 02:29 AM   #2 (permalink)
yota44's Avatar
View yota44's Photo Gallery
The pump is right under the resovoir. Try removing the resovoir and cleaning it out. One of my jets stopped spraying all together so i blew some compressed air throught it and it worked like a champ.
88 Toyota 4X4 22re. Comp 260s cam, Pacesetter header, 2 1/4 straight piped, 50 Series Flowmaster, K&N cone filter adaptor, bunch of other useless shit
yota44 is offline   Reply With Quote
Old 09-08-2008, 02:35 AM   #3 (permalink)
just a nobody
The washer pump should be mounted on the bottom of the washer jar. Here is a link to show you how to get to it: http://www.autozone.com/shopping/rep...00c15280061054.
However, if it is working, your problem is not the pump itself, it may just need to be clean; either way, the above link will show you how to remove it, just wash the screen and the jar out, that may be the only repair you need to do.
N.E.O.
Old 09-08-2008, 03:41 PM   #4 (permalink)
Quickywd01's Avatar
View Quickywd01's Photo Gallery
Can you use a pump off a camry? My pump fell apart. When I was at the junkyard they had no pickups but had a camry.
1990 Deluxe Xtra 4x4 3.0L auto
Quickywd01 is offline   Reply With Quote
Old 09-08-2008, 04:27 PM   #5 (permalink)
just a nobody
Maybe, most of the time the differences between the pump are their connectors, and the direction of the inlet and outlet. Pull yours off and compare it.
N.E.O.
Old 09-08-2008, 09:21 PM   #6 (permalink)
TN Member
trivletrav's Avatar
lol NEO you're pretty knowledgeable about washer fluid pumps...thanks for the suggestions all of you!
i probably won't get to it until this weekend...for now i'm doing school
lol
Old 09-08-2008, 10:01 PM   #7 (permalink)
just a nobody
What was that saying now. Oh yeah, 'Been there and done that'.
N.E.O.
