several problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-08-2008, 01:00 PM   #1 (permalink)
View 93yotaman88's Photo Gallery
several problems
i have a 93 pick up with code 14 blinking, the speedo doesn't work until you drive down the road a little way, and i was wondering what some problems would be if the the tps was bad.
93yotaman88 is offline   Reply With Quote
Old 09-09-2008, 01:42 AM   #2 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
Code 14 "IGF signal from igniter is not input to ECM for 6
consecutive ignition." Right from the 1993 FSM. Looks like you got an igniter problem. Unhook the battery for 30 mins. It will clear the codes, if it comes back. You will know for sure.
Diagnostics page from the FSM:
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Symptoms of a bad TPS:
Bad fuel mileage
Bad throttle response
Read up on it here:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
Old 09-10-2008, 02:08 AM   #3 (permalink)
View toyo89's Photo Gallery
I also got a code 14 and traced it back to an exposed wire going to the coil. A little tape and problem solved. Hopefully your problem is this easy.
toyo89 is offline   Reply With Quote
Old 09-10-2008, 07:02 PM   #4 (permalink)
Ex-Master Diagnostic tech
View hevster1's Photo Gallery
Mr moderator, a little FYI. if there is an ignitor problem it does not start. If you want to clear codes just pull the 15 amp efi fuse. That said the code is a catch all. Exposed wires or various relay issues could be the problem. Ck the coil wiring.
Ex Toyota MDT 28 years of experience. I still fix them daily by appt only. Written warranty-great prices. References available.
hevster1 is offline   Reply With Quote
