big problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-08-2008, 07:52 PM   #1 (permalink)
View patty16's Photo Gallery
Canada big problem...
Hi, my name is Patrice
I just join that group recently. I own a pick up 4x4 1991 with the four cylinder engine. Here is my problem. When i am driving over 80 kpm i can ear a loud noise (and the truck is shaking) comming from under the truck, somewhere between the engine and the back. The noise get louder while i'am going faster. If i put the truck on neutral while it running (over 80)the noise is still there. If I push the cluth pedal, the noise is still there. BUT, if i'm releasing the gas pedal i am not earing the noise anymore ??? At the moment that i put the feet on the gas pedal the noise is coming back...IT is not the muffler (that is for sure). Do you think it's the differential or the transfercase ? Can it be a universal joint ?
Thank's for the answer
patty16 is offline   Reply With Quote
Old 09-08-2008, 10:34 PM   #2 (permalink)
Saving lives
IronNam's Avatar
Gameroom cash: $580920
View IronNam's Photo Gallery
driveshaft must be out of balance
94Hilux-XCab-22RE-W58-8"V6
IronNam is offline   Reply With Quote
Old 09-08-2008, 10:38 PM   #3 (permalink)
denniswoo's Avatar
View denniswoo's Photo Gallery
i agree it sounds like the drive shaft.check all the joints make sure they have grease and aren't loose when you move the shaft at the u joints.if one of them has bad needle bearings it will most likely be dry and really loose.
denniswoo is offline   Reply With Quote
Old 09-09-2008, 03:31 PM   #4 (permalink)
The Official TN Member
boypilot's Avatar
Gameroom cash: $127049
View boypilot's Photo Gallery
I had the exact same problem. The bearings in the rear u-joint fell apart and were causing the drive shaft to shake. Just replace the u-joint and you should be golden.
'92 4wd 22-RE, 6" Lift, 35x12.5 Trxus MT, 5.29's w/ lockrite, 5speed swap, Downey Header w/ 2.25" Flowmaster 40
-Entirely painted in bed-liner
WWW.CARDOMAIN.COM
22RE Engine Rebuild Thread
boypilot is offline   Reply With Quote
Old 09-09-2008, 06:56 PM   #5 (permalink)
Vicoor's Avatar
View Vicoor's Photo Gallery
could be u-joints, climb under and see if the ujoints have play, and see if they get hot after driving.
But your description sounds more like a a differential or trans problem.
Don't talk about it, Just do it!
22RE, xtreme ported head, crane cam, cust manifold, MegasquirtII-Extra(full sequential inj/spark), 300cc inj, adj reg, supra fp, LCE header, W58, short throw shifter, 14lb flywheel, kevlar clutch, 4.10 gears &Truetrac, drop spindles...
Vicoor is offline   Reply With Quote
Old 09-09-2008, 07:19 PM   #6 (permalink)
Krusty's Avatar
View Krusty's Photo Gallery
u-joints
also found on TinBenders.org
Pirate4x4.com
92 22RE x-cab 4x
and a 86 22RET as a 'truggie' rock crawler
pics in photo gallery-- Krusty
Krusty is offline   Reply With Quote
Old 09-10-2008, 11:12 AM   #7 (permalink)
boypilot's Avatar
you could always put it up on stands and look under there while its running in drive. See if anything isn't normal... like drive shaft wobble.
WWW.CARDOMAIN.COM
Old 09-10-2008, 09:16 PM   #8 (permalink)
Saving lives
IronNam's Avatar
ARE YOU TELLING HIM TO PUT JACKS UNDER THE REAR DIFFERENTIAL ASSEMBLY AND PUT IT IN DRIVE?!
kinda crazy, but possibly dangerous
Old 09-11-2008, 10:28 AM   #9 (permalink)
boypilot's Avatar
If your carefully and smart about it it's perfectly safe. You gotta get all four wheels off the ground and make sure its stable but I've done it dozens of times. I gives you the opportunity to really see whats going on down there.
WWW.CARDOMAIN.COM
Old 09-11-2008, 05:16 PM   #10 (permalink)
Saving lives
IronNam's Avatar
haha i would trust my self to do it on a 2wd tho. and alot of jacks. its reasonable anyway
Old 09-12-2008, 12:30 AM   #11 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
Does it make the noise in reverse? Sounds like when it transfers load to the backside of whatever is making the noise is stops. U joint probibly.. Thank goodness they are easy to replace.
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
