Sounds like a major intermittant connection somewhere in the main current to the distributor (duh). I think you knew that already. Are the wires old? Especially the wire going to the center of the distributor and the circuit feeding that center wire, the coil, etc.
Also, since the problem is electrical it would be in the replaceable parts of the distributor. Probably won't have to replace the whole distributor to fix it.
Oh yeah that thing in the center of the distributor that goes around and around... can't remember the name. Maybe it is the problem. The rotor that's it yeah... the rotor. If it's badly corroded oxidized blackened etc it may be the intemttant point of failure.
06 xB 16,003mi.
00 Ody 94,800 mi.
99 Saturn 118,000mi.
95 Celica 124,000mi.
89 HILUX 22R 219,452mi.
