Upper Radiator Hose - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-09-2008, 03:10 PM   #1 (permalink)
View SkyLynx's Photo Gallery
Upper Radiator Hose
Hello Everyone,
I have a small leak in my cooling system. The end of the upper radiator hose which connects to the engine is the part that is leaking. I just replaced the hose but now the metal housing at the mid point (just before it connects to the engine) is now leaking coolant. I couldn't find the gasket for the housing anywhere. Would rtv gasket maker seal it up?
Thanks in Advance.
92 V6 4WD
SkyLynx is offline   Reply With Quote
Old 09-09-2008, 04:11 PM   #2 (permalink)
View pickup's Photo Gallery
RTV should work. Did you ask an auto parts store for the gasket? It may come with a new t-stat also.
pickup is offline   Reply With Quote
Old 09-09-2008, 05:03 PM   #3 (permalink)
Yeah I asked several parts stores if they carried it. They didn't mention the t-stat either.
I'm going to try the rtv and see if it works. If i remember correctly, the packaging says to allow 24 hrs. to cure so i should know by then.
Thanks again.
Old 09-11-2008, 12:23 AM   #4 (permalink)
The rtv worked. The only problem i have now is overheating. After about 10 min of test driving the temp gauge started to climb. I guess air got trapped in the cooling system when i disconnected the upper radiator hose.
Old 09-11-2008, 01:32 AM   #5 (permalink)
let it idle with the rad cap off, preferably with the front end higher than the rear (not necessary, but helps) Bounce the front end even, to get all the air out of the system. And blast your heat. then when you don't see any bubbles coming out anymore you can put the cap back on. This could be easier with a bleeder screw, but I don't think our trucks came with them.
Old 09-11-2008, 01:59 AM   #6 (permalink)
Saving lives
IronNam's Avatar
Gameroom cash: $580920
View IronNam's Photo Gallery
just top it off with alot of clean non hose/ tap water
94Hilux-XCab-22RE-W58-8"V6
IronNam is offline   Reply With Quote
Old 09-11-2008, 02:00 AM   #7 (permalink)
Saving lives
IronNam's Avatar
btw i havent seen you much around here, but you are definetly welcome to this forum. if you have any questions, you may ask us, we are very happy to help
Old 09-11-2008, 02:14 AM   #8 (permalink)
Who is this directed to?
Old 09-11-2008, 02:42 AM   #9 (permalink)
yota44's Avatar
View yota44's Photo Gallery
just topping it off won't neccasarily get rid of the air
88 Toyota 4X4 22re. Comp 260s cam, Pacesetter header, 2 1/4 straight piped, 50 Series Flowmaster, K&N cone filter adaptor, bunch of other useless shit
yota44 is offline   Reply With Quote
Old 09-11-2008, 02:52 AM   #10 (permalink)
werd, far away from solving the problem
Old 09-11-2008, 05:14 PM   #11 (permalink)
Saving lives
IronNam's Avatar
oh skylynx and everyone thats new.
pickup i've seen you around here and you are also welcomed too haha
Old 09-12-2008, 04:20 AM   #12 (permalink)
Thanks for the warm welcome buddy!
Old 09-12-2008, 03:10 PM   #13 (permalink)
View maxpower_hd's Photo Gallery
For future reference you can easily make your own gasket. I do it all the time. They sell the material in rolls. Get the heavy duty stuff if you can. then spray the housing with something, I use Dikem, and press it onto the material and cut out the pattern.
As for the overheating, you need to burp the system. Let it run for a bit with the radiator cap off. You should be able to tell when it burps. Then top it off. It may take a couple of tries.
"The normal make a living. The deranged make history." -Christopher Titus
maxpower_hd is offline   Reply With Quote
Old 09-12-2008, 09:38 PM   #14 (permalink)
Saving lives
IronNam's Avatar
No problem man! TN is such a great place, i actually visit here more than my old past forums, like DF haha
Old 09-14-2008, 10:14 AM   #15 (permalink)
Thank's for the help guys. I really appreciate it. I was able to get rid of the air in the cooling system using the techniques you all suggested. However, it appears now i have more serious problems... I start to change my oil and I notice a brownish - chocolate milk like substance on the bottom of my oil cap. I have read on other posts that this could indicate a head gasket failure or timing chain cover issue. The truck is idling very rough and I'm still losing coolant. After the oil change i checked the dipstick and it still has a normal amber looking color.
Does repair of the HG or Timing chain require any special tools?
