What weight fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-09-2008, 11:39 PM   #1 (permalink)
View pickup's Photo Gallery
What weight fluid?
For the trans and transfer case? I see that it should be 75/90, but I can only find 80/90 I like to think that it wouldn't matter, if not be better since it's so old.
Also, all I have seen is GL3/4/5 all in one bottle, but I have read that GL5 eats the syncros. I find that hard to believe, but don't know.
Thanks!
pickup is offline   Reply With Quote
Old 09-10-2008, 09:33 PM   #2 (permalink)
Quickywd01's Avatar
View Quickywd01's Photo Gallery
I'd like to know. What specific stuff have you guys used? I want to do this since I don't know when it was last done.
1990 Deluxe Xtra 4x4 3.0L auto
Quickywd01 is offline   Reply With Quote
Old 09-10-2008, 09:46 PM   #3 (permalink)
I did find some 75/90 today. But it was mobil one. At 10 bucks a quart. This truck takes about 17 quarts including the diffs, no way I'm doing that, overkill.
Old 09-12-2008, 12:43 AM   #4 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
I used Amsoil synthetic manual transmission fluid (gl4) and Amsoil synthetic in the transfer case. Aswell as in both the diffs
Get a nice GL4 gear oil for your t-case. 85w-90..
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
Old 09-12-2008, 04:25 AM   #5 (permalink)
Why do you recommend 85/90? Toyota recommends 75/90? Not a big difference, but I'm anal and need reason.
Old 09-12-2008, 03:01 PM   #6 (permalink)
Krusty's Avatar
View Krusty's Photo Gallery
the first number is the viscosity of the oil---- and since you are not worried about 'flow' , it doesn't make a daymn bit of difference !!!!!!
any 75-80/90 will work !!!! (Marlin recommends 80/120 !!!) so what ???? the parts are immersed and won't know the difference !
as in engine oil----- toyota does not recommend Mobil 1-- so you shouldn't use it ??????
in the winter i run 10/40, in the summer i run 20/50--- (i live in the mojave desert and it gets HOT in the summer !
in the tires-- i usually run 28/35 psi in my '93--- in my 85, i run 8 and 5 psi !!! NOT what toyota recommends---- but they don't run 36's and don't know the application in which i use the trucks !!!!
toyota uses 'red' antifreeze--- so you can't use green-yellow-purple ?????
also found on TinBenders.org
Pirate4x4.com
92 22RE x-cab 4x
and a 86 22RET as a 'truggie' rock crawler
pics in photo gallery-- Krusty
Krusty is offline   Reply With Quote
Old 09-12-2008, 03:55 PM   #7 (permalink)
Thanks for clearin that up!
Old 09-12-2008, 08:02 PM   #8 (permalink)
Vicoor's Avatar
View Vicoor's Photo Gallery
you will likely find that your tranmission will shift stiffly when cold if you use 80w90. I've found that 75w90 GL-4 works best.
Its no problem to use 80w90 or 85w90 GL-4 or GL-5 in the transfer or the rear diff.
if you've got a ADD front diff you definitely want to use GL-5 in it.
p.s. I think they hold 17 pints not quarts
Don't talk about it, Just do it!
22RE, xtreme ported head, crane cam, cust manifold, MegasquirtII-Extra(full sequential inj/spark), 300cc inj, adj reg, supra fp, LCE header, W58, short throw shifter, 14lb flywheel, kevlar clutch, 4.10 gears &Truetrac, drop spindles...
Vicoor is online now   Reply With Quote
Old 09-17-2008, 02:34 AM   #9 (permalink)
Supafly
Jayota's Avatar
My mistake, I run 75w-90 in my diffs and t-case. I just made a typo I ran 80w-90 in there for awhile... no biggie.
Oh and btw, toyota red coolant is best I use it... talk about anal! Its 2x the price of green antifreeze..
Old 09-17-2008, 07:38 AM   #10 (permalink)
New TN Abuser
flashkl's Avatar
View flashkl's Photo Gallery
Nobody really answered the question about the GL3/4/5 labelled bottle.... I
m doing this for my truck too since I ran in high water last weekend, the local NAPA has 80/85W-90 gear oil that's labeled as GL3/4/5 on the back. Can I use that for both diffs, the t-case and the MT?
-Kai
Edit:
Also, I've been using Peak green coolant, what exactly are the cons of using that and not red yota stuff? Should I really be worried about it?
KaiYota - '92 Pickup Xtracab 4x4
Veezy - Flowmaster - SAS - Locked - Super shiny Longs - 35" kevlar MT/Rs - Not enough armor
http://picasaweb.google.com/flashkl/KaiYota
flashkl is offline   Reply With Quote
Old 09-17-2008, 11:00 AM   #11 (permalink)
Gameroom cash: $399685
View V62WDLongbed's Photo Gallery
Yes you can use that NAPA fluid in everything. In the winter you might find the shifting a bit stiff until the fluid warms up is all. I prefer synthetic fluids myself.
Had you been using the Toyota red coolant all along I would have recommended you stick with it. Since you haven't don't worry about it.
V62WDLongbed is offline   Reply With Quote
