horrible engine noise. please help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-10-2008, 09:48 PM   #1 (permalink)
View jamesn's Photo Gallery
my truck (220k miles 22re 5 speed) started making a horrible noise yesterday. like marbles in a metal can being shaken. the noise fades away when you rev the engine up to 3k rpms. i had a leaking water pump so i replaced that. it was not causing the noise.
using my mechanics stethoscope, it sounds like its coming from the front of the valve train. it looks like the timing chain guides are still in place and the chain is not hitting the inside of the timing cover. i adjusted the valves. the noise is still there.
could it be the distributor?
any other ideas?
jamesn is offline   Reply With Quote
Old 09-10-2008, 10:07 PM   #2 (permalink)
View Rickisan's Photo Gallery
Man I would make sure the timing chain tensioner is doing its job. You probably already know if something happens there it can ruin the engine. I don't know how to do that externally though. Hopefully someone with more experience will comment.
06 xB 16,003mi.
00 Ody 94,800 mi.
99 Saturn 118,000mi.
95 Celica 124,000mi.
89 HILUX 22R 219,452mi.
Rickisan is offline   Reply With Quote
Old 09-10-2008, 10:12 PM   #3 (permalink)
how can you tell if the tensioner is going bad or if it is out? i dont know.
Old 09-11-2008, 12:47 PM   #4 (permalink)
denniswoo's Avatar
View denniswoo's Photo Gallery
if the engine has over 220k on it and with the history of chain wear on these things,and if the chain has never been replaced i think i would replace it.the kit comes with everything you need for about $80.you need to have a good strong light and look down past the top drivers side plastic guide the top section on my engine looked good until i got a really good look.
denniswoo is offline   Reply With Quote
