Alternator Fuse Stuck In Fuse Box
I washed down the engine bay pretty good one day and since the alternator was gunked up pretty bad with oil buildup I scrubbed and hosed it down pretty agressively with water and degreaser. Note: Degreaser is kinda of like "Deplane! Deplane!" but he was actually a character from the movie West Side Story... well never mind...
Started the truck up and drove around the block for 15 minutes to dry everything real good. All seemed fine.
Next day it started up fine but the Alternator/Brake lights were on all the time driving to the store. They never came on while driving before. Also the engine idles high all the time now instead of slowing down to the correct idle speed after 5-10 minute warm-up like it used to. I never sprayed any water on the Carb either so that one really baffles me.
Figured maybe I got grease in the Alternator and have now replaced the brushes since the commutator inside was very black but the brushes looked long enough to make contact so not sure yet if that will help. Installing that back in tomorrow to see what happens there.
That's the history... my problem/question is...
Thought maybe the water could have blown the fuse but when I try to pull the 80A fuse out of the black fuse box inside the engine compartment it won't budge. The adjacent fuses came out with reasonable force using fingers only. So using pliers to get a little more grip managed to remove some of the plastic and clear cover from the Alternator fuse but it won't come free of the socket or move any at all.
Decided to spray a little Boe-Shield in there to try and loosen it up. Maybe over the years the fuse has gradually "welded" itself to the socket? It is passing 40 - 50 amps at times? Or maybe my water fun caused an unusually high current to have an immediate "welding" action from an alternator malfunction during my "dry out drive"? Any ideas on how to get this fuse to release? Will the fuse box itself come loose so can push from underneath? Or any other way to ease it out with out destroying the fuse and the soceket? thanks for any ideas
06 xB 16,003mi.
00 Ody 94,800 mi.
99 Saturn 118,000mi.
95 Celica 124,000mi.
89 HILUX 22R 219,452mi.
