93 Waterpump Accident Question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-12-2008, 03:10 PM   #1 (permalink)
View FLybye's Photo Gallery
Hi Alls!
Quick question:
My brother crashed my 93 P/U. I was taking everything apart to replace the radiator and fan clutch when I noticed the water pump pulley was pushed back about .25-.5"/6-13mm. It was pushed back enough to lock up the water pump.
I was thinking of just replacing the water pump, but then I started wondering if anything behind the water pump could have also been damaged.
Before I purchase the things I need to get, do you guys feel this minimal damage is not enough to cause any problems behind the water pump? Worst case scenario, I'm thinking possible block damage, etc. I didn't take the pump off because I'm missing a few tools that I need. So I figured I'd just ask here before going out and buying it all.
FLybye is offline   Reply With Quote
Old 09-12-2008, 03:16 PM   #2 (permalink)
View maxpower_hd's Photo Gallery
I would guess it is only the pump shaft that is bent. You're going to have to take it off anyway. Just take it off BEFORE you buy the new one just in case.
"The normal make a living. The deranged make history." -Christopher Titus
maxpower_hd is offline   Reply With Quote
Old 09-12-2008, 07:31 PM   #3 (permalink)
Vicoor's Avatar
View Vicoor's Photo Gallery
V6 or 4cyl?
If it is a 22RE 4cyl I'd suggest pulling the waterpump off and inspecting for damage to the timing cover.
If it is a 3VZE V6, the fan clutch and pulley do not attach to the waterpump, it is a "fan bracket" and is less likely to have caused further damage. The waterpump is under this fan bracket and is driven by the timing belt.
Sounds like a lot of damage,
good luck
Don't talk about it, Just do it!
22RE, xtreme ported head, crane cam, cust manifold, MegasquirtII-Extra(full sequential inj/spark), 300cc inj, adj reg, supra fp, LCE header, W58, short throw shifter, 14lb flywheel, kevlar clutch, 4.10 gears &Truetrac, drop spindles...
Vicoor is offline   Reply With Quote
Old 09-12-2008, 10:31 PM   #4 (permalink)
denniswoo's Avatar
View denniswoo's Photo Gallery
if it is a 22r that front timing cover is aluminum and would give before the block, i would still look closely at the block.the timing cover has a volute in it for the water pump make sure that is not damaged either.
denniswoo is offline   Reply With Quote
Old 09-13-2008, 03:06 AM   #5 (permalink)
It's the 4cyl.
Thx guys. Water pump is coming off in the morning. Guess I need to worry bout the timing chain cover.
Old 09-13-2008, 04:30 PM   #6 (permalink)
Great news!
No damage to the rear of the water pump area. Shaft was simply or whatnot. but the important thing is that the blades/shaft didnt move back far enough to cause any damage.
