1992 pickup WILL NOT STOP STALLING. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-12-2008, 04:20 PM   #1 (permalink)
feddaneed's Avatar
View feddaneed's Photo Gallery
I have a 1992 pickup, 22re engine with fuel injection. When I start the truck, it will run, then stall, even if I keep the gas pedal down. A friend of mine messed with the turn signal bulb on the passenger side, it died instantly—and ever since, my truck will not run for more than a full minute. I replaced the ECU, but that was not the issue. The problem is not readable, since the feedback when diagnosed by machine is not clear. I am thinking it may be electrical, and something may have fused or grounded out. Any ideas?
feddaneed is offline   Reply With Quote
Old 09-12-2008, 04:35 PM   #2 (permalink)
View toyo89's Photo Gallery
Try checking the coil wires to see if they are shorting out. Also check the distributor cap for cracks and other wires in the ignition system. Hopefully it's something simple. Also, pull the codes to see if anything pops up.
toyo89 is offline   Reply With Quote
Old 09-12-2008, 08:36 PM   #3 (permalink)
Wicked Clown Juggalo
cd_god's Avatar
View cd_god's Photo Gallery
Front or rear turn signal bulb? The battery and fuse box are on the front passenger side. Did he remove the battery or cables or something in that area while messing with the bulb? If he did check that all of the battery terminal connections are tight and hooked up. If everything looks ok try backtracking and undo whatever he did. Unplug the turn signal, check for pinched or grounded wiring, etc.
cd_god is offline   Reply With Quote
Old 09-12-2008, 09:21 PM   #4 (permalink)
Saving lives
IronNam's Avatar
Gameroom cash: $580920
View IronNam's Photo Gallery
make sure the pipe between teh Throttlebody and the VAFM is secured and not leaking....
94Hilux-XCab-22RE-W58-8"V6
IronNam is offline   Reply With Quote
Old 09-14-2008, 09:14 AM   #5 (permalink)
Ex-Master Diagnostic tech
View hevster1's Photo Gallery
Check the fuses and fuse links first both inside and under hood.
Ex Toyota MDT 28 years of experience. I still fix them daily by appt only. Written warranty-great prices. References available.
hevster1 is offline   Reply With Quote
Old 09-15-2008, 09:56 PM   #6 (permalink)
View moldycheese's Photo Gallery
will it run if you play with the throttle? if it does you may have a bad connection on your MAF sensor, or it could be fried all-together.
moldycheese is offline   Reply With Quote
