are you better than four mechanics? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > 89-95 Toyota Pickup/Hilux
89-95 Toyota Pickup/Hilux Discussion forum for the 89-95 Toyota Pickup/Hilux owners. NEW!
Old 09-12-2008, 05:35 PM   #1 (permalink)
View toyo89's Photo Gallery
Here is a problem that is quite challenging in that four mechanics at the same garage could not figure it out. I hope one of you can put this mystery to rest... I had a reman engine put in my truck recently and since I had a hard time shifting I told the garage owner to go ahead and replace the clutch while you're at it. The mechanics put the clutch in - the clutch would not go into gear. They bled the clutch real good. Nothing. The owner thought that he was sent the wrong clutch so he ordered another one. Same thing happened again. The mechanics replaced the slave cylinder and master cylinder (actually they went through three slave cylinders). The truck wouldn't go into gear at all. The garage owner decided that he must have gotten a bad clutch or the wrong one for my truck again. By this time I was pissed so I got the VIN from the truck and ordered the clutch parts from the Toyota dealership myself. The owner had the nerve to ask me to pick them up (50 miles away). I had to go to work. The mechanics picked up the parts and installed the clutch, throwout bearing, release bearing, pressure plate, everything new except flywheel and clutch fork. The same thing happened again. The truck would not shift into any gear. Turned out the slave cylinder piston was't reaching the clutch fork. No one seemed to know why. I asked the owner how the flywheel looked. He said it looked new and he didn't have it resurfaced - he didn't see any reason to. I told him I thought it was standard practice to mic the flywheels, inspect them and have them resurfaced. Again, he said it looked new. I asked if the clutch fork was bent. He said they never bend. Of course I knew better and I had already kicked myself a hundred times for taking the truck to these demolition men. But the damage was done. They ended up rigging the truck by welding a 1/4 inch rod onto the slave cylinder piston. This worked for two months until the piece broke off. The owner told me that he talked to his son (another mechanic) who told him that my flywheel must have been worn too much. I reminded him that he said the flywheel looked new. He said it did look all shiny and new but it must have been worn beyond resurfacing.
So what do you think? What could cause the clutch not to engage with all new parts except for the flywheel and clutch fork? Also, the adjustment at the pedal is adjusted all the way out. This is a 1989 3.0 3vze 4x4. 5 speed manual.
toyo89 is offline   Reply With Quote
Old 09-12-2008, 07:56 PM   #2 (permalink)
Vicoor's Avatar
View Vicoor's Photo Gallery
I'm sure I can find at least 4 mechanics that I am better than,
But really it sounds to me like you may have found 4 wannabe mechs.
The last line of your post may be the key.
The adjustment at the pedal is only to adjust the pedal height and "toeplay"
If it is adjusted too far it will prevent the master cylinder from returning to the rest position, and this will prevent proper bleeding.
If it is adjusted all the way out and it does still have play in the pushrod at the master cylinder, look for flex and or cracking around where the master cylinder bolts up to the firewall and it's support bracket.
one other thing to look for under the dash is wear around the clevis pin in the pedal arm.
It's hard for me to imagine what could be wrong in the bellhousing. a bent arm or extremely worn pivot, but either of those would be very unusual.
If you can't see anything wrong like I've descibed under the dash, I'd suggest finding a real technician that is familiar with your truck. Anyone can speculate about a problem like this based on your desciption, but without a first hand inspection it is just speculation.
Good luck
Don't talk about it, Just do it!
22RE, xtreme ported head, crane cam, cust manifold, MegasquirtII-Extra(full sequential inj/spark), 300cc inj, adj reg, supra fp, LCE header, W58, short throw shifter, 14lb flywheel, kevlar clutch, 4.10 gears &Truetrac, drop spindles...
Vicoor is offline   Reply With Quote
Old 09-12-2008, 08:05 PM   #3 (permalink)
just a nobody
It is possible that you have a crack or broken clutch pedal mounting bracket. When you press on the clutch pedal, the bracket is flexing rather than pushing the clutch master cylinder push rod to disengage the clutch. Get a light and look underneath the dash when the pedal is mounted, see if the bracket is flexing when you put down on the clutch pedal.
N.E.O.
Old 09-12-2008, 10:23 PM   #4 (permalink)
denniswoo's Avatar
View denniswoo's Photo Gallery
you can measure the rod length at the slave cylinder when you depress the clutch.there are specs on that.and if it is within specs you either got a bad fork or combination of bad fork and flywheel machined previous if you are a second owner,machining in itself wouldn't cause this problem.
denniswoo is offline   Reply With Quote
Old 09-13-2008, 04:06 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
flywheel is most likely ok... machining is only resurfacing and it certainly wont put a flywheel so out of spec that the clutch wont work.
Possible theres something wrong with the cylinders of the clutch and the guys at the garage dont know what they're doing.
Old 09-13-2008, 07:43 AM   #6 (permalink)
ohgood's Avatar
View ohgood's Photo Gallery
(this is the wrong shop to be using)
is your plastic doo-hickey at the bottem of the shifter worn out ?
never weld on load bearing things, especially if you're not certain the cause of the problem. they have a tendancy to come apart at the worst possible time.
ohgood is offline   Reply With Quote
Old 09-14-2008, 09:10 AM   #7 (permalink)
Ex-Master Diagnostic tech
View hevster1's Photo Gallery
N.E.O.
The above is the most likely cause. While a clutch fork being bent is possible I have never seen it. These are a real PIA to bleed at times. I have also seen the rubber hoses collapse and not allow the proper travel.
If a flywheel is machined too far it could cause this but again this is unlikely as you would have to machine a whole lot of material. However certain aftermarket clutches require the use of a matching flywheel. If you had one of those clutches and the same one was not installed there could be a problem.
My advice to you as some others have said here is to bring it to a professional. I would also demand at least the labor back as they obviously didn't fix your truck and jury rigged it to get it out of their shop. Try www.asashop.org or www.iatn.net for a shop. Good luck.
Ex Toyota MDT 28 years of experience. I still fix them daily by appt only. Written warranty-great prices. References available.
hevster1 is offline   Reply With Quote
Old 09-15-2008, 08:32 PM   #8 (permalink)
Thanks you guys! I found the problem. The adjustment at the pedal was messed up. I adjusted it out and now the clutch catches at the top. All I have to do now is adjust it down close to halfway and the clutch should catch at halfway. I don't know why the mechanics didn't check this. It sure cost them alot of money.
Old 09-15-2008, 08:42 PM   #9 (permalink)
just a nobody
Why would the adjustment be out to start with? It is a hydraulic clutch, so it shouldn't need any adjustment unless the master cylinder was replaced previously and it wasn't adjusted properly.
N.E.O.
Old 09-15-2008, 08:58 PM   #10 (permalink)
Young Toyota Tech
View Turboman412's Photo Gallery
becouse when u install a new clutch were a used one was. the adjustment of the grap point is going to be diffrant
Turboman412 is offline   Reply With Quote
Old 09-15-2008, 09:14 PM   #11 (permalink)
Vicoor's Avatar
The proper adjustment is so that there is 10mm freeplay(toeplay) at the pedal.
Once this is set there is no reason to have to touch it again unless you replace the clutch master cylinder.
Old 09-15-2008, 09:28 PM   #12 (permalink)
View moldycheese's Photo Gallery
but these "mechanics" probably bent or tweeked something when they removed the transmission resulting in the adjustment issue
moldycheese is offline   Reply With Quote
Old 09-15-2008, 10:20 PM   #13 (permalink)
just a nobody
Its hydraulic, the adjustment doesn't change, it is self-compensated; the push-rod in the slave cylinder will retract to compensate for the wear of the clutch disc. The clutch pedal adjustment should stay the same, except for the engagement point; new clutch closer to the floor, as the clutch wear, the engagement point would move higher.
N.E.O.
Old 09-15-2008, 10:23 PM   #14 (permalink)
just a nobody
Clutch mechanism don't bent very easily, and there is only the clutch fork that they have to contend with.
N.E.O.
